Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Pass Labs This forum is dedicated to Pass Labs discussion. |
#11 |
The one and only
Yes, we want the voltage across the resistors.
And be careful, that's 78 volts... |
#12 |
You may want to buy the rubber high voltage gloves technicians use on electric/hybrid cars. You can find them at most electric supply stores.
They are bulky and uncomfortable, your hands will sweat inside them, however, it sure beats accidentally touching 78 vdc, That kind of early retirement is not what it's cracked up to be.
ACA v1.6 monoblocks, Balanced Zen Line Stage, M2x, B1 Korg triode, 12AX7a Phono amplifier, Balanced B1 Korg triode, 6FG6 "Magic Eye" tube VU meter |
#13 |
What voltage do I have to have in each of the 1ohm resistors?
#14 | |
The one and only
And you can use the following guide to get to 50 deg C. |
#15 |
thanks for helping me but I'm a little lost
Where do I have to take a voltage as a reference and what should it be? I have the temperature probe. |
#16 |
Official Court Jester
post pictures and it'll be shown
my Papa is smarter than your Nelson ! clean ![]() ![]() ![]() |
#17 |
The one and only
There are a bunch of 1 ohm resistors on the output stage. Each of them has
two wires coming out at the end. The DC voltage is between one of those wires and the other. |
#18 |
I already have it set at 45 degrees Celsius and it is perfect.
Now I have to adjust a T200 that I don't have the adjustment values. Thanks for the help |
#19 |
Just got a couple of SA-2 that run a bit cold to the touch.
I am planning to inspect them and adjust the bias if needed. Would anyone be able to confirm that 150mV is the correct value for the voltage drop across the emitter resistors? Thank you in advance for any help. Marco |
#20 |
@ Marcomariutto: Correct! I have attached a picture from the manual.
Thread | Thread Starter | Forum | Replies | Last Post |
threshold s/450e | miguelnoda | Solid State | 2 | 20th November 2019 11:06 PM |
Threshold S500 optical bias - filter caps and bias - experience so far | eswaroop | Pass Labs | 9 | 13th April 2019 05:57 PM |
Threshold S/500 bias set up anyone? | stevieg123 | Pass Labs | 31 | 24th August 2016 06:31 PM |
Bias adjusting on Threshold SA4/e | Mywing | Pass Labs | 19 | 10th June 2010 04:35 AM |
Threshold SA4/e bias | nchelazzi | Pass Labs | 2 | 16th June 2008 09:10 PM |
New To Site? | Need Help? |
