How do you measure bias with no source resistors?
Old 14th November 2019, 09:56 PM   #21
damuffin is offline damuffin  Canada
If your really lazy and In a fiddling mood you can use a laser temperature gauge on your big heat sink. I don’t recommend this method for first time bias, but if you think it’s a little hot or a little cold this is by far the easiest.
Old 14th November 2019, 10:15 PM   #22
Mark Johnson is offline Mark Johnson  United States
diyAudio Donor
Mark Johnson's Avatar
FLIR camera is even easier, and it gives you a softcopy record (photograph) of the reading.
Old 14th November 2019, 10:15 PM   #23
wrenchone is offline wrenchone  United States
wrenchone's Avatar
A while ago, I nabbed a Fluke Y8100 clamp-on DC current probe on E-pray. This is what we used at my last job for power supply current measurements without breaking the line to insert an ammeter. It plugs into your standard DVM and outputs a voltage that is a function of current.
Old 15th November 2019, 12:55 AM   #24
Extreme_Boky is offline Extreme_Boky
Originally Posted by GKTAUDIO View Post
Like this?
one resistor is fine; don't need two.
Old 15th November 2019, 01:11 AM   #25
GKTAUDIO is offline GKTAUDIO  United States
GKTAUDIO's Avatar
Perfect, thank you. I suspected that after posting the image, figuring placement might depend on enhancement vs. depletion mode FETs (d vs. s).
How do you measure bias with no source resistors?Hide this!Advertise here!
how to measure and match source resistors 0,22-1ohm? elviukai Pass Labs 14 7th May 2006 05:15 PM
How to measure resistors below 1R bigpanda Parts 6 19th June 2005 05:02 PM
SMD resistors measure badly after soldering? motherone Parts 18 4th March 2005 04:57 AM
quick bias tolerance question...across source resistors Mattyo5 Solid State 6 12th October 2003 12:09 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
