FET-9 Restoration / Update
Old 10th November 2019, 11:54 AM   #1
Geeqner is offline Geeqner  United States
Default FET-9 Restoration / Update
New member here - recently got my grubby paws on what appears to be a well cared-for / clean 1st-gen FET-9 from the original owner.
I HAVE searched for related posts, but most of them are several years old.
My thoughts / questions:
Given its almost 30 year age - I plan to preemptively replace only those components that are prone to leakage / degradation, which points to the Electrolytic Caps. I have also read that the selectors and Pots are of a SEALED type - so NO spray-cleaner on those.
I’m also a big believer in the “if it ain’t broke - don’t fix it” theory, so I want to address potential problems, but with a MINIMAL approach.
Q1. I’m thinking Panasonic for the Power Supply Section and Silmic II’s for those associated with the Signal Path Biasing. Is that still recommended?
Q2. Are there any other items worth attention on the initial go-Round?
Looking at the External Power Supply - my impression (no insult to the original designer intended) is that it seems pretty “wimpy” for something used to power a high-end unit. I know that this IS a pre-Amp, and it has a relatively low current draw, and that the “fancy-pants” regulation takes place on the main unit Motherboard. However- My Product Research on the FET-9 & 10 family has shown the substantially upgraded units that were provided later.
Initially, I plan to just update the filter caps and try it. -BUT-
Q3. For those of you who have Upgraded or Replaced the Power Supply:
3A. Was it worth the effort and cost?
3B. What did you actually do?
Old 10th November 2019, 06:51 PM   #2
elwood625 is offline elwood625  United States
elwood625's Avatar
Nelson Pass replied to a post from someone regarding capacitors to replace on a FET 10 HL, if you search for FET 10 you may find it. It was within the last year, just don't remember when, however, I would follow what Nelson has to say about capacitors.
I bought a FET 9 in 1985 along with an S300 amp, big mistake selling those. My FET 10Pe is still my favorite audio component.
ACA v1.6 monoblocks, Balanced Zen Line Stage, M2x, B1 Korg triode, 12AX7a Phono amplifier, Balanced B1 Korg triode, 6FG6 "Magic Eye" tube VU meter
Old 11th November 2019, 02:52 AM   #3
Also, does anyone have or know where to find labeled PCBA drawings or photos for the Boards within the “plain Jane” version of the FET-9?
I found a copy of the Service Manual that has Schematics, but it’s hard to tell which component is which and the boards are not labeled/marked. I’ve found stuff for various versions of the 10, but NOT for the basic-9.
Old 11th November 2019, 06:15 PM   #4
baeijsman is offline baeijsman  Denmark
I changed the original (Mallory) caps in the power-supply for my FET10.
I honestly wasn't able to hear any difference at all.
Next I had Teddy Pardo build a replacement-supply. (Yes, I was lazy)
This made a huuuuge difference!
It clearly helps the amp reveal just how epic it really is!
I haven't made any changes to the amp itself.
Old 11th November 2019, 08:54 PM   #5
kstagger is offline kstagger  United States
kstagger's Avatar
For my FET-10/HL redo - a few years ago - I used Silmics everywhere, including the outboard power supply. I didn't hear any change but at least I knew it would be good for another decade or two.
Old 11th November 2019, 09:44 PM   #6
INITIALLY - I'm planning to replace just the Electrolytics, including those within the External Power Supply (My 1st-gen FET-9 does not appear to have any potentially troublesome Tantalums in it.)
That will let me play with my new toy (Hopefully, REALLY bring-out what my AR TT / Shure V15-Vmr can do - I'm sure that the Phono Stage should blow-away the one in my NAD Receiver that is presently serving Pre-Amp duty.)
THEN (Later) - I plan to build one of the Upgraded Power Supplies that others have made for the FET-10 Series. A project like that should be relatively simple and is well within my means and abilities. [I figure that a little Judicious "overkill" can't hurt - so long as it's done right and relatively inexpensive to do so.]
Old 15th November 2019, 06:50 PM   #7
Put Power Supply on Voltmeter and Oscilloscope, to attempt to get a fairly accurate evaluation of the condition of this "oldie but goodie":
V+ = seems OK, nearly flat output at about 29.8 VDC
V- = seems OK-ish, about 31.8 VDC with around 40 mV of ripple on it (iffy cap?)
I assume that the secondary regulation should handle any difference, but before attempting that, I'm going to replace the Power Supply Caps (they're arriving 2-day!)
Does anybody have pics / layout drawings of the FET-9 "Plain Jane" version that show component names/numbers and what Voltages / Signals the various standoffs carry?
(MY version does not have the 20-pin connectors between the Mobo and the Phono / Line-Stage Board. Gold-Plated stand-offs, washers, and Allen-Key screws are used to carry Voltage and Signal between the boards.)
Zen Mod's linked page shows the "/e" Version, which is different from mine. Tried E-mailing the "current" Threshold, but wonder if there is anybody there NEmore...
Old 21st November 2019, 08:43 AM   #8
Replaced caps in separate Power Supply and Output Voltages remained about the same.
How concerned should I be about the difference between V+ & V-?
(Do they “Even-Out” under load? Or, Does the Secondary Regulation on the Main Unit Motherboard take care of this?)
I KNOW that there are Trimpots for fine-tuning the Regulated V+ & V-. The Service Manual specs what to set these at, but my copy does not show WHERE the Test Points are for this measurement. A semi-educated guess would dictate seeking and checking 3 of the Gold-Plated screws / stand-offs that are used to carry Power & Signal between the Phono/Line-Stage Board and the Motherboard, (logically, 3 of them on the end nearest to the Power Regulation Section) but it would be nice to know for certain which are which.
(There are about 16 such cross-connects and I can make some logical assumptions about what such connections SHOULD be “present”). I believe that I have schematics for the FET-9e, which uses about 6 separate modules for Regulated Power, Line, & Phono in L & R pairs for each, and uses 20-Pin connectors in place of the plated standoffs & screws that are used on mine, but I am certain that the circuits are still VERY similar and I CAN draw some logical parallels between that one and mine. (Mine pre-dates the Op-Amp-Based Servo Control biasing circuitry shown on the more modern “e” model.)
The way I guesstimate it, there SHOULD be:
-Raw Phono IN L/R = 3 or 4 points [trace to Jacks separate rate or combined Signal Ground?]
-Amplified Phono OUT = another 3 or 4 points [to Mobo for Source Selector Switches]
-Raw Line IN = [from Source Selectors] 3 or 4 points
-Line OUT = [To Volume Controls / Tape Source Selectors] 3 or 4 points
-Regulated Power IN [maybe multiple sets] = but at least 3 or 4 points
[I can find / identify these by fishing-Around with my Voltmeter and checking continuity]
Zen-Mod, can you PLEASE double-Check your archive of Literature, and see if you have a copy of the 1st-Gen Service Manual and / or the Circuit Board layout / labeling drawing or pics and maybe the schematic for this particular model?
One last item about the Electrolytic Caps for this unit:
-I know that Nelson Pass has recommended ELNA Silmics (Silmic II)
-However, it seems to be difficult to find these in the proper PHYSICAL size and Voltage for my unit
(Checked both Mouser & Digi-Key, and Newark)
-The 4 470uf Caps on the Mobo are hard to find in the shorter 35V version
(There may be room to “lay-over” some slightly larger 50V ones on their side that I got before realizing that they are too tall by about 7mm)
-The 2 “shorties” 470 if in shorter still 25V version
I want the replacements to be DURABLE, so I want sufficient Voltage Margin (rating vs applied) plus best Service Life available. What are thoughts on Nichicon KA series, which appear to be relatively new, and have higher temperature and service life ratings, while also being intended for Audio applications? I know that Nichicon has a good reputation for quality and this series seems to be more readily available in the sizes that I need.
Old 21st November 2019, 10:16 AM   #9
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
pics, please
plenty of them
if you have difficulties posting properly shrinked ones , find a way to send biggies to me (dropbox or something) or directly to my email , so I'll shrink them and post here
>zenmodiyaudio@gmail.com<
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 21st November 2019, 12:49 PM   #10
Mine appears to be essentially the same as the one that renehc posted
See previous thread “Threshold FET Repair Story”
(Same orange Mallory caps in Power Section and blue shorties at Phono end of upper PCBA = the end with the DIP switches for Cartridge Loading...)
Mine has S/N 220, so I would guess pretty early production
FET-9 Restoration / UpdateHide this!Advertise here!
Mtx 311 d update ^HELP^ onthethreshold Car Audio 7 4th April 2011 08:25 PM
Bozak restoration/update Skoda_101 Solid State 0 17th November 2006 04:20 AM
a thanks & HT sub UPDATE pne123 Subwoofers 0 15th February 2004 03:26 PM
JLH Update GringoAudio Solid State 6 8th March 2003 06:12 PM
A40 update doktor Solid State 0 11th February 2001 12:05 AM
Copyright ©1999-2019 diyAudio
