Forte Model 3 Issues
Old 7th October 2019, 08:17 PM   #1
koenigr is offline koenigr
Default Forte Model 3 Issues
Hello community,
Having some issues with a Forte Model 3 amplifier and would love some input. The left channel was blown to smithereens; multiple output devices, both driver transistors, and 3x small MPS transistors (I replaced all failed devices with new parts).
Powering up on a variac, everything runs perfect up until about 90VAC, after which the bias jumps wildly out of control, quickly jumping up to >1V. If I push it any further the line fuse blows, but the rail fuses remain intact.
I've disassembled the left amp board multiple times and at this point have tested every single resistor, transistor, and diode out of circuit, all measure okay with a multi-function transistor tester. I've also re-flowed every joint with fresh solder, still no luck
Has anyone run into similar issues? Also worth noting: I already replaced the bias trimmer with a new multi-turn trimmer.
Thanks in advance!
Old 8th October 2019, 01:18 PM   #2
Here are some photos if it helps
Old 8th October 2019, 03:08 PM   #3
AVWERK is offline AVWERK  United States
AVWERK's Avatar
The A968 driver is non existent these days so hopefully it survived
Old 9th October 2019, 12:35 PM   #4
Thanks for the tip! The original 2SA968 was blown and I replaced it with parts supplied by the owner, come to find out they were counterfeits purchased on eBay that crap out at higher voltages. Replaced with MJE15032/MJE15033 and all is well!
Forte Model 3 IssuesHide this!Advertise here!
Kriesler stereo 6 model 11-133b Radiogram volume issues L/R channel output issues chrisg21 Tubes / Valves 1 15th January 2019 09:24 AM
Forte Model 6 Amp lpd Swap Meet 0 18th October 2017 07:56 PM
Converting Forte Model 3 to Model 1a LouieTheG Pass Labs 2 7th May 2015 04:42 PM
Forte model 3 4krow Pass Labs 21 7th May 2015 04:02 AM
Forte Model 1 hum tonywood Solid State 2 20th May 2014 08:10 PM
Copyright ©1999-2019 diyAudio
