Ask help on PASS X150 dc output differential settings
Old 10th October 2019, 06:10 PM   #41
gelly is offline gelly  Belgium
Zen,
there is no c5, c6. (capacitor)
maybe you mean header 5 and 6 ?
if you menth, header 5 and 6,
those are the measuring points for the IQ. (IQL1 and IQR1)
measuring not referenced to ground but between the 2 pins (1 header)
like you stated in your blog,
all measurements are made with inputs shorted (cinch and xlr). no speaker attached.
the absolute voltage is measured between ground and the (red or black) speaker terminal.
now, after 3,5 hours, playing very low volume, the temperature is risen to:
left 51.2 and right 50.3 degrees c. (ambient = 22)
Old 10th October 2019, 06:39 PM   #42
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
gimme full picture showing main board and I'll show which caps are C6 and C7 (there are four big horizontal electrolytics on pcb , near connection block)
if there is symmetrical voltage at them ( and it will hardly be anything other) , you'll need new UGS modules , as Wayne sez
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 10th October 2019, 06:45 PM   #43
ah, that one, not noticed, sry, here it is.
Old 10th October 2019, 06:52 PM   #44
Zen Mod's Avatar
yes , these two ......
and ?
Old 10th October 2019, 07:29 PM   #45
unfortunately, about the new measurements, that would be possible at earliesest on saturdayevening or sunday.
Old 12th October 2019, 02:21 AM   #46
Maybe a stupid question...
The measurements are made with inputs groundet.
Rca short, clear.
Xlr short,... the standard amp's u short between 1 and 3 ?
That is only grounding the negative input. ( is what i did).
Should i have shorted pins 2 and 3 maybe ? (Positive and negative pins)
Old 12th October 2019, 03:38 AM   #47
wayne is offline wayne  United States
Auburn
wayne's Avatar
The inputs are cap coupled so it shouldn’t really matter much for the measurements. They can be made with the inputs open. If the amp works and the sides are about the same temperature but the DC is off you may need new gain modules if they can’t be set to zero.
wizards assistant
Old 12th October 2019, 05:35 AM   #48
Are those gain modules still available and what is their pricetag ?
Is there a way to determine/measure on those gain modules to be shure to avoid the efforts and costs ?
Old 12th October 2019, 04:18 PM   #49
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
The modules can be had from the factory. Kent would let you know what the
cost might be (his job description is Customer's Best Friend).
kente@passlabs.com
I would also ask him for referral to a good technician in Europe.
Old 15th October 2019, 07:54 AM   #50
An update.
Have received the needet info from Mr Kente (pass labs)
Great and fast response, very helpful informations.
Will be Continued...
Greetz from belgium.
Ask help on PASS X150 dc output differential settingsHide this!Advertise here!
Pass X150 Tom B. 57 Pass Labs 78 29th May 2019 08:18 PM
Pass X150 specs Sonance84 Pass Labs 8 19th February 2019 04:34 PM
Pass X150 DC Protection info Mark Veter Pass Labs 9 18th January 2019 04:46 PM
Pass X150 Where does it sit in the overall line up ?? Old'n'Cranky Pass Labs 168 1st December 2017 12:40 AM
pass x150.5 barti Pass Labs 2 18th October 2008 04:03 PM
Copyright ©1999-2019 diyAudio
