Ask help on PASS X150 dc output differential settings
Old 7th October 2019, 08:22 PM   #11
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Et Voila!
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 7th October 2019, 08:39 PM   #12
gelly is offline gelly  Belgium
Wayne, zen, ...
you mean the 2 untagged center ones ?
witch pcb is what ?
top/bottem pcb left or richt channel ?
what about the p1 , p2 , p3 and p4 ?
will this regulation solve also the bopping at power on/off ?
sorry for that many questions guys.
just dont wanna make mistakes on this precious piece of equipment.
guys, tnx in advance !
edit… witch measuring pins are what ?
1 near c1 , c2 , c3 , c4.
Old 7th October 2019, 08:47 PM   #13
wayne is offline wayne  United States
Auburn
wayne's Avatar
The two outside pots set the bias. Set very carefully.
On the small board the pot on the side that says Pass is the offset compared to ground. The one on the side that says UGS4 is differential set this first measure from red to black on speakers. Then move one lead to RCA ground and set offset to 0. Go back and forth till both are close to 0. This should reduce noise at turn on and off.
wizards assistant
Old 7th October 2019, 09:03 PM   #14
Wayne,
remaining,...
top/bottem pcb (2 identical ones) in picture = left or right channel ?
witch measuring pins are for left/right, (A bias, B bias) ?
Old 7th October 2019, 11:40 PM   #15
Auburn
wayne's Avatar
There are 4 sets of pins. Two on the left and two on the right. We used a connector to a voltmeter on these. You don't want to short them be very careful. Each pot on the main board matches up with a set of pins closest to it.
Bias is set at 125mV to start check and set so they are even and temp is 45-50 C
wizards assistant
Old 7th October 2019, 11:51 PM   #16
Auburn
wayne's Avatar
wizards assistant
Old 8th October 2019, 03:54 AM   #17
Tnx wayne,
Nice job tagging the pic !
Now,
The 2 left biasses are for the left channel ?
And,...
The 2 small pcb's, the top one is left, the other right channel ?
Gonna try to fix me a second dmm and connectors today.
Greetings
Old 8th October 2019, 04:51 AM   #18
Auburn
wayne's Avatar
The bias pots match up with each corner and side. Left front for left front side.
Left rear for left year side. The amp-is balanced and has four channels.
wizards assistant
Old 8th October 2019, 09:30 AM   #19
Okay,
Bit confusing with those 2 pcb's.
For differential offsets adjusting, i suppose the rear pcb is left channel and the front pcb is the right channel ?
Or way round ?
Old 8th October 2019, 09:42 AM   #20
Would it not be better (more clear to me) to tag each pot and measuring pins accompanied with channels, so that no mistakes could be made ?
Example: left channel offsets.
Offset left diff. OFDIF_L
Offset left abs. OFABS_L
Example: Bias right channel.
BI_POS_R.
BI_NEG_R.
Sorry for my stupid questions guys...
Greetings from belgium.
Ask help on PASS X150 dc output differential settingsHide this!Advertise here!
Pass X150 Tom B. 57 Pass Labs 78 29th May 2019 09:18 PM
Pass X150 specs Sonance84 Pass Labs 8 19th February 2019 05:34 PM
Pass X150 DC Protection info Mark Veter Pass Labs 9 18th January 2019 05:46 PM
Pass X150 Where does it sit in the overall line up ?? Old'n'Cranky Pass Labs 168 1st December 2017 01:40 AM
pass x150.5 barti Pass Labs 2 18th October 2008 05:03 PM
Copyright ©1999-2019 diyAudio
