Bi Amp Opinion
Bi Amp Opinion
Old 6th October 2019, 02:51 PM   #1
JSA1971 is offline JSA1971  Canada
Bi Amp Opinion
Default Bi Amp Opinion
Hello All,
Iíve been feeling the need to tinker or experiment with bi-amping a pair of speakers. Iím currently using my M2-x as my main amplifier but also have my DIY Aleph J which is sitting around waiting for itís turn to be put back into service. Iím asking for opinions as to which one would be best used in the Mid/Upper range and which would be better suited for the lower frequency duty and why that might be. I do realize they have different input sensitivities for their respective rated outputs so Iíd probably need an electronic crossover to compensate.
Any suggestions or opinions would be greatly appreciated!
Old 6th October 2019, 06:29 PM   #2
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
Bi Amp Opinion
M2x low duty, but not that much work to try both ways.
I build, therefore I am.
Old 6th October 2019, 09:10 PM   #3
Bi Amp Opinion
Absolutely an easy swap to try out, lol. I was just thinking that someone with more experience than I would have an idea why one might be better than the other for the low duty. I do know that the Aleph J (which I love and was my first build) is great into 8ohm loads but power is reduced into smaller loads, whereas the M2-x can deliver more power into lesser loads. Although I donít have any test information for my particular speakers (vintage JBL 150ís) that show impedance plots, I have read many reviews of speakers that seem to indicate that impedance dips usually reside in the lower frequencies so my initial thought was to try the M2 amp for the woofer. I know that my speakers arenít bi-ampable by construction but my plan was to disconnect the woofer leads and install an additional set of binding posts to wire the woofer independently and use an electronic crossover to provide the slope and crossover point that the internal crossover provides. If it doesnít sound good, I can just put it back as original.
Old 6th October 2019, 09:16 PM   #4
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Bi Amp Opinion
don't leave bass xover parts in circuit , if you're not using it's function
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 6th October 2019, 10:08 PM   #5
Bi Amp Opinion
Hi Zen Mod, the crossover plate in the speakers is rather large and not easily accessible as I found out when I recapped it last year. What problems or issue can you shed light on by just using the crossover to continue feeding the midrange and tweeter?
Thank you
Old 6th October 2019, 11:07 PM   #6
olsond3 is offline olsond3  United States
2nd order or higher crossovers can present very low impedances to the amplifier when there isn't a driver connected. Without the driver there, the circuit is just a coil and capacitor in series across the amplifier terminals. At the resonant frequency, it can look like a short. I blew up a very expensive amplifier this way several years ago.
Old 6th October 2019, 11:32 PM   #7
Zen Mod's Avatar
Bi Amp Opinion
I'm saying that just for bass section , if you disconnect driver from xover, leaving the same fed with amp
6db one will flap in breeze , so no biggie , while 12ddb and higher ones are having something shunting to gnd , and without driver as final load , that's no-no , as olsond3 already said
Old 6th October 2019, 11:37 PM   #8
Bi Amp Opinion
Thanks for your reply oslond. Would putting an 8 ohm resistor in place of the woofer help with this or would this not work because itís not ďthe sameĒ type of resistive load created by the speaker coil in a magnetic field? Sorry for the non technical thought.
Old 6th October 2019, 11:38 PM   #9
Bi Amp Opinion
Thanks Zen Mod
Old 7th October 2019, 12:13 AM   #10
Zen Mod's Avatar
Bi Amp Opinion
wasting energy of amp on a dummy load
there is really no choice - are you or not disconnecting unloaded portion of xover
Bi Amp OpinionHide this!Advertise here!
Opinion about PCB Oskar2905 Solid State 10 5th January 2018 02:42 PM
Need your opinion/help dmxas Construction Tips 3 26th September 2016 06:45 AM
Need opinion tony Ma Power Supplies 19 26th March 2013 12:19 PM
your opinion please. motor_maniac18 Car Audio 5 29th September 2005 06:45 AM
Your opinion on 813? Jax Tubes / Valves 5 16th January 2004 09:10 PM
Copyright ©1999-2019 diyAudio
