Bi Amp Opinion
Bi Amp Opinion
Old 7th October 2019, 12:20 AM   #11
JSA1971 is offline JSA1971  Canada
Bi Amp Opinion
Originally Posted by Zen Mod View Post
wasting energy of amp on a dummy load
there is really no choice - are you or not disconnecting unloaded portion of xover
Thanks Zen Mod, understood. Seems like Iíll have to make time for the removal of the crossover plate if Iíd like to try out the bi-amp project. Iíll look at the schematics and then see if thereís a place to disconnect and create a jumper to re attach it.
Old 7th October 2019, 12:24 AM   #12
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Bi Amp Opinion
post schematic here , pics also (if you have them ) , so we can figure out together - if needed
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 7th October 2019, 01:38 AM   #13
Bi Amp Opinion
As always Zen Mod, your help and advice is greatly appreciated. From looking at the schematic it appears (to me) that if I detached/clipped/created a jumper on the lead going from coil L1 to the positive input of the crossover board that it would isolate the woofer crossover components. Am I correct? If memory serves it should be very easy because the coils have long leads on them.
File Type: jpeg 8F2516B5-BE43-4B40-BD02-8A0EFF2530DE.jpeg (457.2 KB, 129 views)
Old 7th October 2019, 02:33 AM   #14
Blues is offline Blues  United States
Blues's Avatar
You might prefer the AJ on bass as it has a higher gain than the M2 (don't know the M2X). If you have a large room higher gain on the low end will help otherwise it will sound anemic on bass and the high end too loud. If you are able to tune it with an external active crossover then you can experiment both ways. Try with the existing crossover first before deciding to spend on actives.
Old 7th October 2019, 02:44 AM   #15
Dennis Hui is offline Dennis Hui  Canada
Hoopy Frood
Bi Amp Opinion
According to FIRST WATT PRODUCTS there is a 5dB diff in gain between
the M2 and the AJ, so you likely will need to have some facility to adjust the
line level going into the two amps.
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 7th October 2019, 05:02 AM   #16
Zen Mod's Avatar
Bi Amp Opinion
yup
Old 7th October 2019, 04:01 PM   #17
Bi Amp Opinion
Thanks everyone for your input and suggestions! Looks like I have some more research to do before I go ahead. From what Iíve been reading an active crossover using something like a mini dsp would fit the bill and even allow for independent gain settings and outputs to the two amplifiers.
Bi Amp OpinionHide this!Advertise here!
Opinion about PCB Oskar2905 Solid State 10 5th January 2018 02:42 PM
Need your opinion/help dmxas Construction Tips 3 26th September 2016 06:45 AM
Need opinion tony Ma Power Supplies 19 26th March 2013 12:19 PM
your opinion please. motor_maniac18 Car Audio 5 29th September 2005 06:45 AM
Your opinion on 813? Jax Tubes / Valves 5 16th January 2004 09:10 PM
Copyright ©1999-2019 diyAudio
