Hi Gianluca,
nice to see you here, best greetings from Alex and Carsten!
Common guys NP's generosity to share ideas is enough for me.
This really is not enough to keep you busy?
We should just explore from a hundreds or thousand ways permutation how to get rid of heat.
Leave that signature heat sink design to FW customers, or just buy the original?
the middle one looks lovely.
Yes, I think that the second is perfect but the problem is, more complicated = more hours of machining= more expensive.
@indra1,
There's something to like about the simplicity of that last one.
The Modushop drawings don't include the mounting holes for the back, so I'm not sure what the spacing is. It also occurred to me that the Modushop front panels are attached from the back rather than drilled-through and counter-sunk, so maybe there's no advantage to be gained there anyway....
Jeff which mounting holes are you refering to? Let me know if I can be of any help.
And yes, all our 10mm front panels are attached from the back
Thank you Gianluca, the drawing should help if it is drawn to scale.
This was just to show you the distance between the mounting holes and the edges of the panel, if you need the complete drawing so you can see all the dimensions you can find it attached to this post
Let me know if this sketch can help!
Nice.
Using my pdf software scaling tool, I think 125 mm C-C distance between the mounting holes is the other dimension that Jeff and Indra are looking for.
Nice.
Correct!
- Long skinny builders thread
