Pearl 2 - design oversight
Old 8th September 2019, 09:20 PM   #11
PRR is offline PRR  United States
PRR's Avatar
> You could clamp the output
Then why waste 95% of a good 24V rail to make only 0.6V peak output?? We could get that much out of a fresh AA cell. And hi-fi system levels often exceed 0.6V.
Turn-on thump is a real problem in some systems. I note that many mass-market chip-amps claim to have reduced it (by slow turn-on).
In this case I would *also* cast an eye at the following switching-stage which would not swallow a 24V pulse. That's big, but not hard to defend against. In "professional" work inputs are routinely defended against "any" voltage that might appear on stage or studio wires, even power-amp outputs. At line-level, another 10k in series is not a big deal, and 100V in 10k is 10mA, which most switch-chips will eat OK.
Old 9th September 2019, 12:08 AM   #12
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Becuz it's an MC phono preamp, going into a preamplifier.
Read the prospectus carefully before you invest.
Old 9th September 2019, 12:30 PM   #13
rhthatcher is offline rhthatcher  United States
Precisely why I use a power conditioner with a delay function built in. The main reason is one button to turn on the system, and the key feature I wanted was this delay function. Phono and Preamp come on to warm up, then the power amps come on. Opposite for power-down sequence. I got a panamax unit on US AudioMart. Price was right and it had the functionality I was looking for. I'm sure it's one of many such products on the market.
Old 9th September 2019, 06:30 PM   #14
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
Originally Posted by Dennis Hui View Post
Apparently the OP did turn on the Pearl 2 before the Arcam:
Hmm I thought AC coupling was safe
I'm wondering if the Arcam might actually by in stand-by mode when this happened.
Also some preamps that are 'on' when plugged in so it might be advisable to
add a relay to the Pearl 2 output?
Yes I always do. I always power on the Pearl 2 first.
Old 9th September 2019, 07:01 PM   #15
The Arcam was fully OFF.
Old 9th September 2019, 07:04 PM   #16
I don't think that diode clamping is the answer here, I'll be adding a relay clamp.
Old 10th September 2019, 06:49 PM   #17
I step back a bit here after a bit of research. The CMOS switches in the Arcam run at +/-12V which means that their inputs must be clamped at below 12V.
I'm going to go with 10V diode switching for ease of building an external diode clamp.
Old 10th September 2019, 11:31 PM   #18
wayne is offline wayne  United States
Auburn
wayne's Avatar
Something like this would work as a turn on time delay. The resistor and cap values can be changed to your liking.
wizards assistant
Pearl 2 - design oversightHide this!Advertise here!
RIAA caps for Pearl and Pearl 2 AudioLapDance Pass Labs 7 22nd May 2015 07:19 PM
WTB: Pearl 2 PCB rookakoma Swap Meet 3 17th September 2014 12:23 AM
An oversight on a TDA1554q pcb layout nvg07 Chip Amps 3 15th December 2013 01:16 PM
Huge oversight in toroid purchase.... Can I fix? speakrsrfun Chip Amps 14 16th May 2009 06:21 AM
pearl HELP! d to the g Pass Labs 24 31st May 2007 01:56 PM
Copyright ©1999-2019 diyAudio
