Inductor Loaded De-Lite
Old 24th August 2019, 10:52 PM   #11
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
That part is still rated at 200W with the case at 75 deg C.
If you have a big sink you might get away with it.
On the other hand, something less that 50V is probably appropriate....
Old 24th August 2019, 11:51 PM   #12
Jenghis is offline Jenghis
So if the idle current is set to 2.2A, and there is 24V or slightly less at the drain of the MOSFET, then power dissipation at idle should be approximately 53W correct? That will require a big heatsink indeed...
Old 25th August 2019, 04:06 AM   #13
PRR is offline PRR  United States
PRR's Avatar
If the idle is 2.2A, and the load is 8r, you can only swing 17.6V across the load, thus across the device. Taking 2.2V on the resistor and another couple volts lost in the transformer, you want 22V supply, not 50V. (This gives near 20W out for 50W total dissipation.)
The resistors (lamps) are MUCH more lossy, hence the higher voltage for that affair.
Old 25th August 2019, 06:05 AM   #14
Yes I see now that the inductor can make do with much lower voltage than a simple power resistor. It also looks like an inductor may actually be worth the huge added cost over light bulbs. Sounds to me like an 18VAC transformer is the way to go, if the same power supply filter can work with the lower voltage.
Old 25th August 2019, 01:29 PM   #15
oks81 is offline oks81  Norway
Hello!
I have tested something similar with choke.
The transistor was an IRFP 240 and the choke Lundahl LL2733 with the two colis in series.
https://www.lundahltransformers.com/...heets/2733.pdf
I would not recomend use of smaller chokes, bigger is bether.
Old 25th August 2019, 06:23 PM   #16
Originally Posted by oks81 View Post
Hello!
Neat! That choke is huge! How did it sound?
Old 26th August 2019, 01:46 PM   #17
It was ok.
Had to use an 8ohm resistor in parallell with speakers to get more correct freq.responce as the damping is probaly quite low. Or should have built series filters for the speakers, this NP explains in First Watt article.
The nice thing with choke is that it dont give so much heat from bias, except from that probably just as good/bether to build F2 or ACA.
But it was fun building the amp and learning
You need big chokes to stop ripple from PSU, and to get som bass.
Smaller chokes and you get both PSU noice and not so much bass.
I would recommend even bigger than 400mH.
Think Pass used 1000mH on a construction? Am I wrong?
Best
oks
Old 28th August 2019, 12:51 PM   #18
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
This is all very similar to a MOFO. I have made a Mother of All MOFOs (MOAMOFO) with an IXYS running 4.3A and 37v. A CPU cooler with Noctua fan removes the circa 160w just fine.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 28th August 2019, 02:29 PM   #19
adason is offline adason  United States
adason's Avatar
That's amazing X! What speakers are you using it with? Sound? Have you got into tubes yet?
Old 28th August 2019, 09:00 PM   #20
Got Foam?
xrk971's Avatar
Hi Adason,
Thanks! You should stop by my lab and have a listen sometime. The beer is included.
I am driving my usual power hungry 10F/RS225 transient perfect FAST speakers.
Although, recently I have been playing with an OB variant of the FAST speakers. You can see this amp plus a VHeX+ Class AB that I have been playing with on the OB.
Inductor Loaded De-LiteHide this!Advertise here!
Difference between Dayton wire wound inductor vs. foil inductor andy2 Parts 8 21st February 2018 09:54 AM
Front loaded and back loaded horn DrWoofer.com Subwoofers 14 12th April 2016 08:32 PM
Back loaded, front loaded, Iím confused! Silent Screamer Subwoofers 23 4th May 2013 08:54 PM
Combination of Back-loaded Horn and Fron loaded horn?! ARIYAHOOR Full Range 26 1st June 2012 09:20 PM
Copper coil inductor vs. round core inductor tomchaoda Pass Labs 7 21st September 2011 04:42 AM
Copyright ©1999-2019 diyAudio
