Adcom GFA-5002 increase ClassA bias on purpose
Old 12th September 2019, 02:54 AM   #11
Phloodpants is offline Phloodpants
Sorry, I'm wrong about that protection circuit!
The JRC4558 op-amps are definitely for the auto-on circuit. There is no input DC protection, just output protection provided by a UPC1237 chip.
First, the input is unity-gain buffered by one op-amp, then another op-amp boosts that signal by a gain of 122x, which is rectified to charge a capacitor that switches on the 555 timer, which has a time constant around 100 seconds. The remote trigger feeds into this same circuit.
http://hoppesbrain.com
Old 12th September 2019, 07:37 AM   #12
sckramer is offline sckramer  United States
sckramer's Avatar
Attached the schematic and service manual for reference.
Digging how it sounds, especially for late night listening-- very microdynamic with no hardness, and detail at low volume. Really temped to look around for a 2nd to monoblock them.
Cool, re: the 555 timer... saw that chip and figured it must be the timeout after there's no signal- for standby. (or something like that)
Again, I plan on light use only and keep it turned off, or enable the auto-standby mode. It's very hot while on-- Settled on about 50~55degC (direct on the heatsinks) pulling 80Watt from the wall idle.
Scott
Adcom GFA-5002 increase ClassA bias on purposeHide this!Advertise here!
how does fixed bias increase max power? mashaffer Tubes / Valves 32 23rd March 2019 10:26 AM
Adcom GFA-5002 specs? DaveFred Solid State 3 15th July 2018 02:56 AM
Bias increase after components burn in a few days?? gbullimore Pass Labs 1 12th December 2012 05:08 PM
Looking for Help and Schematic Adcom GFA-5002 yagobob Solid State 0 31st March 2011 05:35 PM
Bias opamp in I/V converter position in classA klitgt Digital Source 9 12th January 2005 07:45 AM
Copyright ©1999-2019 diyAudio
