F5 V3
F5 V3
Old 19th January 2020, 10:46 PM   #381
AudioSan is offline AudioSan  Norway
Those CL60's will get very hot. so no heatshrink. Get them a little bit up from any metal. And don't let any wires get glose to them. everytime i use those euroblocks, i cut out a peice of bitumen to have under the Block for extra safety.
Old 19th January 2020, 10:49 PM   #382
chede is offline chede  Germany
... fascinated by amps
chede's Avatar
F5 V3
Originally Posted by jan492 View Post
Also I didn't put shrink wrap on my CL-60 legs because the black insulation on them went far enough down the legs to cover the exposed wire. Hope that's cool.
Hi Jesse,
missing shrinkwrap on the legs of your CL-60's is not the thing that concerns me here. The CL-60's get very hot in use (including their legs) - they're designed that way, to lower their resistance when in steady-state, after the initial switch-on.
Having them so close to the Euro terminal blocks, there's the real risk that you melt away the insulation on the terminals, resulting in a short.
CL-60's short always be mounted vertically resp. well away from every nearby surface, and with their full, unshortened leg length to not put too much heat into the terminal blocks. Have a look at 6L6's build guides ...
All the best, Claas
Edit: ZenMod and AudioSan beat me to it ...
Old 19th January 2020, 10:56 PM   #383
2 picoDumbs is offline 2 picoDumbs  Australia
2 picoDumbs's Avatar
Use this type of terminal block.
1546670-4 TE Connectivity AMP Connectors | Connectors, Interconnects | DigiKey
Bend legs so Thermistor is mounted vertically.
"If you leave this point unattached to some circuitry, an ideal constant current source will emit a small lightning bolt which will travel until it connects to something." Nelson Pass
Old 19th January 2020, 10:57 PM   #384
jan492 is offline jan492
Roger that. I will order the black terminal strips. I'd like to not have ruined my CL60s by cutting the legs off. This pic is from 6L6 guide and shows short legs. Can I do that? Or is there concern that the heat could melt the solder?
TB200-04 Eaton - Bussmann Electrical Division | Connectors, Interconnects | DigiKey
Thank you Chede and audiosan. It's good to have it explained in other words too.
There are an awful lot of pics and guides with the CL60s in euroblocks and very close to other wires.
Old 19th January 2020, 11:05 PM   #385
chede's Avatar
F5 V3
You could use the ones with the short legs still always for the connection between signal ground and chassis ground - normally no current flowing there, no heat. And in case of a fault, they need only to pass so much current that the circuit breaker trips ... so, unlikely to get very hot because of their thermal inertia ...
Old 19th January 2020, 11:08 PM   #386
I allways use a softstart circuit that bypass the CL-60's after a short while.
F5 V3Hide this!Advertise here!
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
