Transformer for F5 - 1 or 2 secondaries?
Old 6th August 2019, 06:03 AM   #11
Staka is offline Staka  Croatia
Last one question, I saw recommendations for bifilar winding of the transformer, does that make sense?
Old 9th August 2019, 12:02 PM   #12
astromo is offline astromo  Australia
News to me. Happy to learn something new.
You may want to think about electrostatic shielding (involves its own earth/ground cable) and other noise mitigation options like GOSS banding.
Old 9th August 2019, 10:19 PM   #13
DougL is offline DougL  United States
Bifilar winding is a technique that tends to make the secondary windings match closely to each other. Having a close match is never a bad thing.
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 10th August 2019, 03:27 AM   #14
rjm121012 is offline rjm121012
You doing a F5 or a F5 Turbo?
For a F5 Turbo you will want a transformer with a dual 24V output or a center tapped 48V output. Both the same. When doing a search on Digikey or Mouser you may get different results depending on output selection. No matter if doing mono block or stereo chassis you will need same type transformer. Only VA rating will change. I see no reason for doing mono blocks on a F5 except for "Bling factor". Additional chassis, transformer, filter caps, etc, etc.
Sometimes a larger rated transformer may be cheaper depending on availability.
Old 10th August 2019, 02:48 PM   #15
I building an ordinary F5 , I gave up from monoblocks, I was thinking of going for dual mono because I thought it was a bigger difference in sound quality, I didn't need more than 25w per channel so I will stay on stereo. I'm in the dilemma of choosing a transformer, a lot of people here use a high power transformers (500,600,800 VA), some even calculate that 500 is optimal for a regular F5 ... I can get a custom transformer at a reasonable price in my city, I just don't know how strong to choose. I have read that transformers of higher power than 300VA have problems with DC from the powerline and that worries me...
Old 10th August 2019, 03:23 PM   #16
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
use 2 pcs of 250VA and make dual mono in one case
take a look at my builds - either blog in my sig or here - latest examples in SissySIT and Babelfish M25 threads
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 10th August 2019, 08:34 PM   #17
McQuaide is offline McQuaide  United States
One 400VA is fine.
Mark
Old 11th August 2019, 07:52 PM   #18
I looked at your blog you have great builds!, you already answered me once about Toshiba jfet (I remember Pipi avatar) and I didn't notice so far that you are from Serbia, may I send you a mail with a few questions?
Old 11th August 2019, 08:28 PM   #19
Zen Mod's Avatar
yup
>zenmodiyaudio@gmail.com<
though , as always is case with me - if I'm not answering on e-mail or PM , feel free to repeat the same
Old 13th August 2019, 03:34 PM   #20
koja is online now koja  Canada
I made a regulated PS for my F5 as per Nelson's Zen 5 paper:
PassDiy
Transformer for F5 - 1 or 2 secondaries?Hide this!Advertise here!
Tribute Line Input Transformer / Phase splitter transformer chrismercurio Swap Meet 3 3rd September 2017 12:25 AM
Single tube guitar amp, adding a transformer to a formerly transformer-less design MereTenacity Instruments and Amps 10 10th March 2013 12:07 AM
Dynaco 440 Transformer Cathode/Screen Taps 6P1P 6AQ5 UL transformer TheGimp Tubes / Valves 14 30th October 2011 12:20 AM
Using a large 60hz toroid transformer as an SMPS transformer EWorkshop1708 Power Supplies 20 22nd June 2011 08:05 PM
toroid Transformer as output Transformer for tube preamp? tone Tubes / Valves 15 2nd February 2003 04:36 AM
Copyright ©1999-2019 diyAudio
