"Triodity" to cancel loudspeaker distortion
Old 12th June 2019, 11:03 PM   #11
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
By this naive approach, actual lower distortion has been measured.
I leave the sophisticated approach to others.
Old 13th June 2019, 12:36 AM   #12
olen is offline olen  United States
olen's Avatar
Itís well understood that cone position (displacement) is directly related to the voltage across the speaker terminals throughout the passband, itís also pretty well understood outside of the passband.
The complication lies in the fact that loudspeaker distortion varies with displacement, Klippel has a lot of great information on this, look up LSI:
http://www.klippel.de/fileadmin/_mig...ity_Poster.pdf
The LSI parameters are typically shown for free-air operation, keep in mind they change when you put the loudspeaker in an enclosure. Ideally a loudspeaker in an optimal enclosure will have symmetrical curves. Conversely, you can start with a perfectly symmetrical speaker in free air and get worse symmetry once itís placed in an enclosure.
Hereís a article/paper on how DC offset relates to distortion:
DC displacement – dynamic offset the voice coil
This is technique typically used to determine if the voicecoil is offset, typically in prototype speakers. You adjust the DC offset to find the minimum distortion and from that you can tell how far your rest position is offset.
-Olen
Originally Posted by Mark Tillotson View Post
Alas the distortion of a speaker is primarily related to the cone position (ie due to suspension forces and voicecoil position), not the voltage across the terminals, and the relationship between voltage and cone position varies substantially across resonance. This probably scuppers chances of naive cancellation.
Without a cone position/velocity/acceleration sensor, the next best way to cancel speaker distortion is perhaps sophisticated model and MPC (model predictive control) techniques. Very compute intensive.
Old 13th June 2019, 09:31 AM   #13
Circlomanen is offline Circlomanen  Sweden
The simple fact that you can use the superficially perceived "flaw" of a simple single stage, single end amplifier to lower the distortion through cancellation instead of relaying on dumb brute force methods like many cascaded gain stages and copious amounts of negative feedback is truly an ingenious use of synergistic effects.
Thank you Mr Pass!!! Your articles about Triodes, SITs and amplifier design in general have really tough me a lot!!!
We live in a horizontal world, why use vertical topologies???
"Triodity" to cancel loudspeaker distortionHide this!Advertise here!
"Quasi-optimal" crossover for high-efficiency loudspeaker system marco_gea Multi-Way 101 12th November 2018 09:31 PM
what makes a loudspeaker "full range"? kneadle Full Range 26 26th June 2018 05:15 AM
Most ultimate 2-way Loudspeaker in low material thickness ? - Kiso Acoustic "HB-1" tiefbassuebertr Multi-Way 8 4th June 2013 04:06 AM
"Sense of depth" in loudspeaker soundstage ? bzfcocon Multi-Way 66 11th January 2012 11:20 PM
"compact loudspeaker factory visit from "magico mini" thread Nanook Multi-Way 2 4th January 2008 07:30 AM
Copyright ©1999-2019 diyAudio
