Using blue Alps as vol control
Old 15th April 2019, 08:24 AM   #1
MEPER is offline MEPER  Denmark
Default Using blue Alps as vol control
I purchased some Blue Alps (50k and 10k) to be used for various pre-amp builds. They seems to be "good enough" for "high-end" use so I don't have to spend 400 USD for e.g. a Khozmo every time (used that for BA-3 pre). But I was a bit surprised how bad the channel match are in these Alps. Only one of the 10k is spot-on. So what do you do? …..just use them without checking the channel match and close the eyes? :-)
For the 50k stereo pots a typical variation between channels if I set at 1 o'clock is something like 12.7k and 12.3k …. 0.4 k difference out of 12k ….so that is 3-4 %. I think that is a lot? ….I have not calculated what that relates to in dB between channels…...so maybe I should do that before complaining to much…...I would like < 1 dB channel error.
Are "stock" Blue Alps "Pass Lab certified"?
Old 15th April 2019, 08:41 AM   #2
ClaudeG is offline ClaudeG
I could be mistaken, but very quickly, aren't 4% mismatch at the end only... 0.34dB?
Old 15th April 2019, 08:44 AM   #3
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
next time buy 100Klin , shunt viper to gnd with 22K and you'll have much better tracking and better LOG transfer function
Potentiometers (Beginners' Guide to Pots)
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 15th April 2019, 09:23 AM   #4
It seems Alps only guarantee <2-3dB tracking error.
Good idea with 100k Lin and shunted wiper. Then I have to find a good quality 100k lin. It seems Alps don't specify lin/log so I assume they are all log.
Old 15th April 2019, 09:29 AM   #5
The tracking on these seems quite good (if we can trust his measurements):
DACT Type 21 Stepped Attenuator Potentiometer 50K for Amp/Preamp, 2A3, 300B... | eBay
I have never seen such a small stepped attenuator.
Old 15th April 2019, 09:32 AM   #6
El Reino is offline El Reino  Finland
DACT is good potentiometer.
Old 15th April 2019, 09:45 AM   #7
I could not resist…..so I ordered 2 pcs of the 10k version. If source can drive it the lower value should be the better choice.
But I think they have "stolen" the name from the "real DACT"?
DACT - Danish Audio ConnecT
Old 15th April 2019, 09:57 AM   #8
Zung is offline Zung  Switzerland
You need to measure the attenuation instead of the absolute resistance value at the wiper, because the resistive elements may vary by up to 10% or more, and the attenuation may still be better than that.
In practice, the ratio Rwiper/Rtotal will give you the attenuation.
Old 15th April 2019, 10:13 AM   #9
Zen Mod's Avatar
I'm pretty much same clueless in Law and Medicine .... but that doesn't mean that there are no laws and cures
first rule of Engineering - you need to learn where and how to find and extract needed information
Old 15th April 2019, 10:43 AM   #10
Yes, but higher risk of contact rectification induced distortion.
Using blue Alps as vol controlHide this!Advertise here!
Alps Blue grounding question Peter 57 Parts 4 28th July 2017 12:22 AM
WTB: ALPS RK27 blue murphythecat8 Swap Meet 2 10th May 2014 04:57 PM
FS: alps Blue motorized pot drptpcpe Swap Meet 0 13th February 2012 12:56 AM
Have you ever seen a 4 pin blue Alps pot??? need help djn Tubes / Valves 6 2nd February 2011 09:39 PM
Alps Blue Velvet Bengali Parts 0 12th March 2009 10:12 PM
Copyright ©1999-2019 diyAudio
