The F4 is a jewel... and seems underestimated
Old 15th April 2019, 02:43 PM   #21
william2001 is offline william2001  United States
william2001's Avatar
Yes sir. That's where I got my pair. I'm hoping someone else will try this out and give their impression. Early days but I think it sounds really nice.
Old 15th April 2019, 02:53 PM   #22
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
well, I did use autoformers in output of line stage
generally , I like what I have as result of using decent Iron in signal chain
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 16th April 2019, 12:17 AM   #23
Russellc is offline Russellc  United States
There's a lot I don't understand about them...didn't you say you got 6dB more gain like this? In F6, I understand there is no gain from transformer, but from solid state bits, while in M2, solid state bits are buffer, and gain is from transformer.....yet your method gives 6dB more, right?
Anyone tried M2's edcore like this?
Russellc
Pass B-1 preamp, Pass BA3 preamp, Wayne's 2018 LS, Pass F-5 Amp, Pass F-6 Amp, Pass BA-3 Amp, Pass M-2 amp, Pass Aleph J amp, Pass Pearl 2 Phono pre Tekton Enzo, Altec A7, Econowave JBL 2235H & B&C CD
Old 16th April 2019, 12:20 AM   #24
I guess this would also eliminate any Dc on output?
Russellc
Old 16th April 2019, 12:35 AM   #25
SanjeevM is offline SanjeevM
The Jean Hiraga too is a great sounding circuit.
RPi 3/ Boss DAC 1.2/ TPA3255/ Linear PSU 5V / Paradigm Monitor 11 / Non-Electronics background
Old 16th April 2019, 01:04 AM   #26
Russellc
Yes, 6db gain per this diagram (stole from Zen Mod). Here's the spec sheet on the Jensen transformer if you need it: https://www.jensen-transformers.com/...-123-flpch.pdf
It's important to drive this arrangement with a low output impedance circuit for the best possible result, hence the buffer you always see in front of them. Wayne's discrete op amp has a fraction of an Ohm.
Old 16th April 2019, 01:10 AM   #27
Russellc
No, not used in this way. It's a single winding with one side grounded. A tiny amount (few mV) is fine.
Old 16th April 2019, 01:31 AM   #28
I'm liking the Burning OpAmp right now with my monoblock F4's. I have a Jensen autoformer between the two for some more gain. But there is something more to adding this signal iron than just gain. I'm not sure what it is, but I like it. Currently rebuilding my linestage to make it all more permanent. It's been just all tacked together for testing.
Now to see if I can de- solder transformer from F6 board. Maybe I should get new set ....I do have some edcors around, seems like someone tried them with a buffer here and wasn't so impressed?
Russellc
Old 16th April 2019, 02:18 AM   #29
I was able to remove mine without any drama. But slinging solder for nearly 30 years maybe helps a little..
About gain needed which is always part of F4 discussion.. I've found with my own situation, 18db in this linestage (12db SS bits, 6db iron) is almost spot on. I don't use any resistive attenuation at all. The digital attenuator in my DAC is not throwing away too much at my normal listening levels. I think gain structure is really important. Some of my old systems had "hair trigger" volume controls before I knew any better.
The F4 is a jewel... and seems underestimatedHide this!Advertise here!
Junk Box Jewel Burnedfingers Tubes / Valves 8 16th November 2018 04:14 PM
How to fit Jewel Bearings ? JewAsh Analogue Source 2 19th November 2010 11:31 AM
How can I modify this grommes little jewel amp for guitar. JZatopa Instruments and Amps 10 2nd April 2010 10:39 PM
Unheard, Underestimated, Underground Music zayne742 Music 18 16th February 2008 05:20 PM
Copyright ©1999-2019 diyAudio
