Buffer with Dual N-Ch Jfets and Dual Power Supply
Thread Tools
Old 6th April 2019, 08:09 PM   #41
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Originally Posted by vdi_nenna View Post
Ok, I understand. How do I find yfs?
Datasheet gives a range or typical.
work first on Idss , think later of Yfs
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 6th April 2019, 08:12 PM   #42
EUVL is offline EUVL  Europe
Datasheet gives you a graph of Yfs vs Id.
You already have all the hints you need from my 2 links to build a high performance source follower with active parts.
No need to use J113 or whatever else.
There are no better N-JFETs than Toshiba, for me at least.
Patrick
xen-audio.com
Old 7th April 2019, 03:30 AM   #43
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
Two very close matched 2sk170 at 9.76 mA gave a dc offset of .3v.
I build, therefore I am.
Do not create problems where there are none.
Old 7th April 2019, 06:38 AM   #44
Assume that you have shorted the input gate to Gnd, and your rail voltages are symmetrical to say 0.1V.
Then something is likely to be wrong with your matching.
If you have matched to 10A under the same temperature, I expect your offset to be < 1mV.
That is when you use Fig. 15c with Rs = 0.
Patrick
xen-audio.com
Old 7th April 2019, 10:42 AM   #45
Zen Mod's Avatar
exact schematic needed
before that , I can only presume that upper source resistor need to be trimmed for offset
Old 7th April 2019, 12:11 PM   #46
vdi_nenna's Avatar
I meant .3mV. Typing on phone late at night...
I tried the formula for Rs, but getting values under 1 ohm. Not sure I'm doing it correctly. Maybe it's because the idss is under required Id?
Old 7th April 2019, 12:13 PM   #47
Zen Mod's Avatar
ok , that's good
checked cold/hot difference?
Old 7th April 2019, 03:21 PM   #48
vdi_nenna's Avatar
Started at .4 mV offset. After a couple of hours on, it's at around .9 to 1 mV dc offset.
Old 7th April 2019, 10:05 PM   #49
vdi_nenna's Avatar
After 4 hours, and turning on the DMM, still settles at .9mA. Goes from 1.1mA down to .9 after a few seconds.
I'm using an 18 Ohm source resistor, because that's close to what the article use and thought it would be safe since I'm using 15v+/- source. I'm having trouble calculating the Rs value.
Old 7th April 2019, 10:07 PM   #50
Zen Mod's Avatar
what's voltage across 18R
Buffer with Dual N-Ch Jfets and Dual Power SupplyHide this!Advertise here!
Thread Tools
Dual jfets kinku Parts 5 20th April 2017 04:21 PM
Who wants 2SK194 Dual Jfets, C3381/A1349 Gr dual pair BJT? Junm Swap Meet 0 28th October 2015 03:17 PM
FS: Dual Jfets in metal can. Tarasque Swap Meet 2 26th July 2015 10:26 PM
Dual supply B1 Buffer andreaemme Pass Labs 0 5th January 2014 09:58 AM
Dual JFETS on EBAY Andypairo Swap Meet 7 11th December 2003 11:04 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
