F5 class AB mode?
F5 class AB mode?
Old 20th February 2019, 08:56 PM   #11
Russellc is offline Russellc  United States
F5 class AB mode?
AB100 Class AB Power Amplifier
Do this?
Russellc
Pass B-1 preamp, Pass BA3 preamp, Pass F-5 Amp, Pass F-6 Amp, Pass BA-3 Amp, Pass M-2 amp, Pass Aleph J amp, Pass Pearl 2 Phono pre Tekton Enzo, Altec A7, Econowave JBL 2235H & B&C CD
Old 22nd February 2019, 08:02 AM   #12
OnAudio is offline OnAudio
OnAudio's Avatar
Thanks Zen Mod
Does this imply you can hear the difference between a switching mosfet and one that’s not switching
That comes to the issue of a particular signature associated with the amplifying device. So we can say mosfet signature , tube signature, nutube signature, bipolar signature , jfet signature, SIT signature etc
Would you say mosfets sound good only with class A operation or when switched at frequencies outside the audio range such as in class D ? Have you ever fancied any class AB amplifier with mosfet outputs ? Have you build any of these 2DIFFET amplifier , POC amplifier , SF Amplifier ? Note the last two are not fully tested but were designed for experimentation.
Would you say the forte of class AB is the BJT? which happens to be risky in class A due to heat.
What would you say about SITs ?
Originally Posted by Zen Mod View Post
I believe people tried
I tried it years ago , but difference (to full A class ) was too much for my liking
of course - if you're satisfied , who can argue ?
onaudio.herokuapp.com
Old 22nd February 2019, 08:08 AM   #13
indra1 is offline indra1  Indonesia
Originally Posted by OnAudio View Post
...What would you say about SITs ?
If you think you need of a bit more grunt, get the Sissy one.
Old 22nd February 2019, 08:15 AM   #14
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F5 class AB mode?
Thanks Zen Mod
Does this imply you can hear the difference between a switching mosfet and one thatís not switching
old farts don't think too much
just one thing - THD spectra is main thing which is differentiating amplifiers
besides that - good amp is good amp ...... you can make one from snails , if you are able ..... and it'll be good as any other good one
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 23rd February 2019, 07:08 AM   #15
brian.goodman is offline brian.goodman  Canada
Default Mosfet Citation 12 - Pass AB Design
The Mosfet Citation 12 is worth consideration for your project given your parts constraints. It is a Pass AB design - low parts count, compact board available from Ingvar Ahlberg for the complementary version, article at PassDiy, lots of posts about it on the Pass forum.
Brian
F5 class AB mode?Hide this!Advertise here!
Difference between voltage mode and current mode Class D amps? Chris Wilson Class D 3 30th January 2019 07:58 PM
class a current mode amp speedless Solid State 2 13th July 2013 02:37 PM
LM4702 or LME49810 work in class A mode to drive the output stages in class A/AB rhythmsandy Chip Amps 29 29th December 2012 11:54 AM
Is it possible for Aleph to operate in class a/b or b mode? audionut Pass Labs 1 8th March 2006 06:07 PM
need to wire 2 kt88/6550 in class a mode! richt Tubes / Valves 13 30th January 2002 03:46 AM
Copyright ©1999-2019 diyAudio
