M2 inspired balanced output preamp idea
Old 19th February 2019, 08:03 AM   #21
indra1 is offline indra1  Indonesia
I just remembered there was this discussion back in 2017 about phase splitter on Hybrid amp thread starting from post #108.
Old 19th February 2019, 12:46 PM   #22
woofertester is offline woofertester  United States
Hello Indra1
Thank you for the thread link. From a cursory reading, it appears that inter-winding capacitances can cause a resonance that leads to distortion. The inter-layer copper purports to reduce the capactitances. This sounds similar to low current triax cables that have a buried guard sometimes called an inner shield. It reduces current leakage and has a side benefit of reducing the apparent capacitance of the cable when driving the cable.
I will have a go at running an impedance sweep of the transformers unloaded and loaded.
Old 19th February 2019, 01:37 PM   #23
damuffin is offline damuffin  Canada
Your loosing the benefit of a balanced source, but if you must split the signal into balanced I’d probably go with opamps. You can probably even test it with the edcor’s in the middle if you change the gain stage to line level. So se buffer edcore balanced and if you don’t like the flavour go back to se gain stage balanced. IMHO Good transformers are expensive and your money would be better spent on a balanced source.
Old 19th February 2019, 01:39 PM   #24
I also would like to quote the Wizard from his 2010 art_arch_nemesis.pdf related to the development process of the M2, F6 and others.
"I have spent quality time with coupling transformers before, but I had never really warmed up to them, possibly because I had not yet reached the 10,000 hour level of listening required to achieve audiophile expertise. In any case, a couple years ago I began experimenting with transformers to solve some problems in a couple of future Zen amplifier projects, and got some fairly good results (good enough for Zens, anyway). Having worked out some circuits, I acquired an assortment of transformers and began evaluating their performance with an eye toward picking the best one. They represented a wide range of cost and materials, and some clearly measured better than others, but when I listened to them I found myself drawn to the sound of one that didn't measure so well.
The dissonance that measures bad/sounds good created called for an unbiased test. So I built two identical amplifiers except for transformers – the very expensive one which measured best, and the unpretentious one that didn't measure so well. I packed them off for a reliable blind test with Joe Sammut, who has 10,000 hours more listening time than me.
“This one is really musical, and that one is not very good.”
Well, that's another data point – a transformer that measures better loses to one that does not. Perhaps if my French was any good, Hiraga would have explained it to me long ago.
Old 19th February 2019, 02:12 PM   #25
It would be interesting to know exactly what did not "measure good".
I have a suspicion that there are possibly more subtle measurements that could explain why one transformer would be more musical than another.
As an example, in the loudspeaker domain, subwoofers specifically, flat frequency response of the bottom octave does not tell much about the quality of the bass. A better measurement is the group delay. A tall narrow peak in group delay indicates a possibility of a boomy one-note experience when listening.
Old 19th February 2019, 02:21 PM   #26
Or simply taste. Now have a good time with the project Brian.
Old 19th February 2019, 02:40 PM   #27
Will do. Thanks for joining the discussion and contributing some very thought provoking ideas.
cheers
Old 19th February 2019, 02:49 PM   #28
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
".........good enough for Zen........."
oh yeah , good xformers are really good enough for Zen
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 19th February 2019, 02:54 PM   #29
Yep, even for Mighty Zen Mod and lotsa lots of others.
Old 20th February 2019, 03:44 PM   #30
For those interested, I powered up one of the buffer boards, a signal generator and a scope.
I used +/- 10V supplies and +/- 24v supplies. No significant difference in behavior that is supply dependent.
Applying 1V AC p-p, the -3dB high frequency point is 1.72 MHz. At the low end, the output is 0dB down at 1Hz. That is as low as my sig gen goes.
The output impedance is 470 ohms. Placing a 470 resistor across the output lowers the output to approximately 0.707 V p-p.
These boards could make a nice low cost buffer block for a DIY crossover. It would be spacious and easy to fiddle with RC values. You would have to account for the 470 ohm output resistance.
cheers
M2 inspired balanced output preamp ideaHide this!Advertise here!
How to add a balanced output to a Tube Preamp ? blackwhaleamp Instruments and Amps 2 6th June 2018 07:53 AM
Balanced DHT-Preamp/Dac-Output anyone ? Blitz Tubes / Valves 6 12th February 2017 02:30 PM
SE to Balanced tube preamp idea hollow_man Tubes / Valves 33 1st October 2009 06:44 PM
hiss in preamp balanced output SSM2142 meaghers Solid State 34 6th August 2008 02:25 PM
Copyright ©1999-2019 diyAudio
