F4 Mono-blocks
F4 Mono-blocks
Old 5th February 2019, 08:55 PM   #11
Itsmee is offline Itsmee  England
Itsmee's Avatar
F4 Mono-blocks
There is enough info to put one together, I'll be using a TL431, Mouser are out of stock of IXFN140N30P untill end of april, I grabbed some IXKN40N60C
Old 5th February 2019, 09:20 PM   #12
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
F4 Mono-blocks Send a message via Yahoo to vdi_nenna
Please let us know what you think of it when done. Pics too...
I build, therefore I am.
Old 6th February 2019, 01:05 AM   #13
6L6 is offline 6L6  United States
6L6's Avatar
F4 Mono-blocks
Originally Posted by vdi_nenna View Post
Do you know if any balanced preamp has the needed gain to drive an F4?
When you say mono block, you mean a stereo one running balanced bridged, yes?
Remember that a standard F4 (RCA in) needs about 40v Pk-Pk from the preamp to make full power (15v RMS)
The same F4, wired into a bridged monoblock (via the XLR) will now need double the voltage to make full power, about 80v Pk-Pk (28v RMS)
I know of exactly one commercially available preamp that can do that...
Old 6th February 2019, 03:04 AM   #14
vdi_nenna's Avatar
That's good to know 6L6. I am aware of the xp30 and what it can do.
How is everyone else doing it? more sensitive speakers?
Mono parallel looks easier to achive.h
Old 6th February 2019, 03:21 AM   #15
6L6's Avatar
F4 Mono-blocks
Dedicated preamp.
Pumpkin, Impasse, Aska Lender, BBA3, etc...
Old 6th February 2019, 10:08 AM   #16
soldersober is offline soldersober  Hong Kong
I have two mono-blocks of F4, four channels in total
When using a balanced pre-amp (Impasse) I use them as monoblocks, with unbalanced pre I donít even bother firing the second box, one channel per side is more (much more) than adequate with my 90bB speakers
My favourite now is driving F4(s) with a DHT pre amp, best of both worlds
Having four channels in two boxes can come handy if you decide to go active crossover route later
Old 6th February 2019, 12:27 PM   #17
PierreQuiRoule is offline PierreQuiRoule  Canada
PierreQuiRoule's Avatar
F4 Mono-blocks
Similar story here: a pair of DIY F4s which I really like. The flexibility of configuring as bridged, parallel, or bi-amp is nice.
Let me add the Aikido tube preamp as a being a good fit (unbalanced output) providing enough voltage swing and gain. I need all the gain I can get for the low output moving coil cartridge. This is less of an issue for digital sources.
Old 6th February 2019, 02:08 PM   #18
vdi_nenna's Avatar
Thanks for the info. There are several balanced preamps to possibly try.
It's hard to choose.
I wrote to Glassware Audio last week asking if any of the Aikido preamps has high gain. Didn't get a response yet. Can you tell me which version you are using?
Thanks,
Vince
Old 6th February 2019, 02:31 PM   #19
kbergsson is offline kbergsson  Iceland
kbergsson's Avatar
Thanks,
Vince
You can tailor gain building the Aikido with various tubes. I built a low gain (10-12db) Aikido using 4 X 6CG7.
Old 6th February 2019, 06:14 PM   #20
vdi_nenna's Avatar
Today I received an email from a local DIY friend and member here.
He has an Aikido preamp I can try out and also has spare PC boards.
Been wanting to build a tube amp or tube preamp for a long time, so this could be a route. Perhaps it has enough gain to drive MoFo to get an idea of what the Aikido can do.
Still, the real target is a set of F4s stereo amps. Everything else is DIY audio icing on the cake!
Thanks!
Vince
F4 Mono-blocksHide this!Advertise here!
F3 mono blocks yup Pass Labs 39 14th July 2018 01:43 PM
heathkit aa-81 mono blocks joshuahhhhhhh Tubes / Valves 15 15th July 2014 01:49 AM
now mono blocks! ksporry Tubes / Valves 0 5th February 2011 08:32 AM
PP KT88 Mono blocks? TubeMack Tubes / Valves 38 11th June 2009 06:41 PM
Copyright ©1999-2019 diyAudio
