Alternate First Watt Power Supply Schematic
Old 10th January 2019, 10:41 PM   #11
xbitwise is offline xbitwise  Europe
Hi Jeff,
I would be interested in Gerbers as well.
xbitwise
Old 11th January 2019, 01:07 AM   #12
gary s is offline gary s  Australia
Hi Jeff.
Not sure how many actual PCB,s you had made, but if you have spares and want to recoup some money, I would be happy to buy some of the spare PSU boards off you.
Gary..
Old 11th January 2019, 02:21 PM   #13
JeffYoung is offline JeffYoung  Ireland
JeffYoung's Avatar
I do have 2 extra boards.
I had them done at Eurocircuits so they're high quality but also a bit on the dear side at 29/each. (6 of that is VAT, so they might make more sense for someone in the EU, but I'm happy to send them anywhere.)
I'll stuff a board in the next couple of days and assuming it works put up the Kicad files and Gerbers.
Jeff.
Old 11th January 2019, 06:55 PM   #14
Jeff, PM sent.
Gary..
Old 11th January 2019, 11:30 PM   #15
JeffYoung's Avatar
Extra boards are spoken for.
Here's the schematic:
Alternate First Watt Power Supply Schematic-decoupledpsuschematic-jpg
Jeff.
Old 13th January 2019, 05:32 AM   #16
Thanks for the schematic Jeff and email reply sent.
Cheers
Gary..
Old 13th January 2019, 08:14 AM   #17
Berny is offline Berny  Belgium
Originally Posted by JeffYoung View Post
Hi Vince,
I've got a board design for that if you're interested.
Hello Jeff, I believe there is a safety issue with your board if you intend to use mains on that PCB as is done in the FW commercial products There are regulations and you need to keep minimum distances between mains voltages and your secondary transformer voltages.... I believe it is about 5mm but am not sure. Be aware...
Old 13th January 2019, 03:51 PM   #18
SRMcGee is offline SRMcGee  United States
SRMcGee's Avatar
Folks:
For what little it's worth, I remember using that sort of power supply design years ago when I started modifying my old Bottlehead Foreplay. Bottlehead referred to it as a "pseudo-dual" power supply. In their design, there was a single transformer, a set of rectifiers and then a shared capacitor bank and then the channels separated with each channel having its own cap bank as a second stage. I had previously used a single shared power supply and recall that the pseudo-dual variation was noticeably better.
Fun stuff!
Scott
Good decisions come from experience. Experience comes from making bad decisions. (Mark Twain)
also, Everyone has a plan, till they get punched in the mouth.(Mike Tyson)
Old 13th January 2019, 04:39 PM   #19
Vunce is offline Vunce  United States
Jeff.
Hi Jeff,
Id be interested in the Gerbers also.
What are the dimensions of your board? Thanks.
Vunce
Old 13th January 2019, 05:59 PM   #20
Murdoc is offline Murdoc  Germany
Hi Jeff,
thank you so much for posting here, I am also hugely interested in the Kicad design, as I postponed mine for more than a year now.
I'm also very happy that you used Kicad, as I wanted to try the new version 6 and set it up so that it works for me (and the audio stuff we all use.).
Thank you!
Matthias
Alternate First Watt Power Supply SchematicHide this!Advertise here!
FIRST WATT B4 + Linear power supply juanitox Swap Meet 6 26th December 2018 11:45 AM
Separate Power Supply for First Watt Amps Russellc Pass Labs 32 3rd September 2018 08:37 PM
looking for power supply diagram SE 813 45 Watt flyingman Tubes / Valves 1 16th February 2005 05:30 AM
55 watt Aksa boards and power supply. Tony D. Swap Meet 4 11th August 2004 07:10 AM
Copyright ©1999-2019 diyAudio
