Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Pass Labs This forum is dedicated to Pass Labs discussion. |
Thread Tools |
#181 |
@JeffYoung
You probably have an ltspice model. I have a request to You. Could you check what the 100hz ripple will be in this configuration: 33000uF capacitors and 0.47R resistors? Now the ripple is 170mVpp. Rail voltages under load +/- 21.7VDC from 18VAC on secondaries. Maybe it will be better? |
#182 |
SPICE predicts 75mVpp.
#183 |
Thank you Jeff
![]() Do I correctly suspect there will be a bigger voltage drop? Regards and Happy New Year |
#184 |
Yes, but not material (~0.05V).
If you're willing to lose some voltage, 1 ohm resistors will nearly halve the ripple again at the loss of about 0.25V. |
#185 |
I have one more board so I can make a better version without desoldering. I wonder whether to install 4pcs 33000uF capacitors before the resistors and 47000uF on each rail after them . Will it be quieter than all 33mF versions?
#186 |
SPICE says 60mV w/0R47s; 35mV w/1R0s.
#187 |
Is there any danger of increasing the capacity and resistance in the filter?
#188 |
More resistance leads to lower-voltage rails and more heat in the resistors.
More capacitance before the resistors puts more of a tax on the transformer (and fuses if you don't have a thermistor or other form of soft-start). More capacitance after the resistors does too, but to a lesser effect. |
#189 |
Thank you Jeff.
I was thinking about a slb power supply but the costs will be much higher with a new transformer so I will work on your project ![]() Last edited by darrr; 4th January 2021 at 10:42 PM. |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Separate Power Supply for First Watt Amps | Russellc | Pass Labs | 39 | 29th March 2020 12:29 PM |
FIRST WATT B4 + Linear power supply | juanitox | Swap Meet | 6 | 26th December 2018 11:45 AM |
looking for power supply diagram SE 813 45 Watt | flyingman | Tubes / Valves | 1 | 16th February 2005 05:30 AM |
55 watt Aksa boards and power supply. | Tony D. | Swap Meet | 4 | 11th August 2004 07:10 AM |
New To Site? | Need Help? |
