Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Pass Labs This forum is dedicated to Pass Labs discussion. |
#21 |
Official Court Jester
counting on fact that I'm having two left legs , am I more of Circlotron , than true complementary type?
my Papa is smarter than your Nelson ! clean ![]() ![]() ![]() |
#22 | |
Say you need fast delivery of cargo anywhere from Peterborough to Folkstone (anywhere between two points). If the cargo is 2-hand size, you can use a moped. Engine the size of a loaf of bread. If it is a Ton, you need a pickup truck. Engine like a dresser. If it is say 500 Tons, you need something even larger. Engine the size of a chicken-shed. Heat-sink (radiator) so big you need a stairway to get to the top. |
#23 |
How do we overcome the effect of Cgd. Consider a 100W or 200W F5 to be built as the current F5 Turbo has got about 4 pairs of mosfets and I believe they are driven by a toshiba To220 package transistors. How many mosfets in total a 2sc4793 can drive without any issues. Secondly how is the stability wrt oscillations when paralleling 10 or pairs of mosfets.
#24 |
The one and only
The bipolars in the F5 Turbo are cascodes. In my book they only count
for shielding the Jfets from voltage, and don't really affect the drive to the output devices. But your question nicely segues into another point worth making - "How do we overcome the effect of Cgd." Cascoding is an excellent way to remove Cdg and Cds. To the extent that Vds, Vdg are held constant by a cascode, you are not charging those capacitances. ![]() |
#25 |
Cascoding the VAS output or drivers?
#26 |
The one and only
Output devices.
Like in the CAS1 and CAS2 |
#27 |
then we need alot of output devices in that case way too higher but is it the way its implimented in x1000?
Looking at the A75 amp the massive output stage was driven with IRF9610 and IRF610 were they sufficient to drive them? |
#28 |
fact: they made it
fact: they published schematic in article fact: many made it from schematic fact : substancial number of specimens is working today still , on owners happiness so , what could be answer to your question? go read a book or two , you can even download them for free
#29 |
The one and only
#30 |
Well produced 100Khz Squarewave instead of distorted because of unable to drive the non linear capacitance from OPS. Not by the IPS or VAS.
Thread | Thread Starter | Forum | Replies | Last Post |
Transformer-driven SEPP output stage. | Circlotron | Solid State | 17 | 20th February 2015 04:22 PM |
passlabs x1000 | claretplace | Pass Labs | 14 | 1st March 2014 10:47 PM |
Output stage transistor type | Willafizz | Solid State | 114 | 12th February 2014 09:09 PM |
Screen driven output stage | nhuwar | Tubes / Valves | 2 | 1st December 2008 06:10 PM |
TV Horzontal Output Transistor for output stage..? | ronybc | Solid State | 46 | 10th October 2005 03:26 AM |
New To Site? | Need Help? |
