Pass X150 DC Protection info
Hi Hi all.
Has The Pass Labs X150 a DC Protecion ?
I have a Pass Labs X150 matched with a Spectral DMC20 S2 preamp
The Spectral allows you to disable ,trough an internal switch, the DC protection for better sound.
But only if the destination power amp has DC Protection itself
Switch on your X150 with input elcaps not bypassed
Switch on your DMC20-preamp
If you don't hear a "plop" in your loudspeakers, then you have a good chance that your preamp has no severe DC-offset on its output
Having switched off your preamp you now can bypass input elcaps from your X150 with no risk; after this switch on your preamp again.
Now watch the woofer: if it stays in its rest position then everything is ok.
