Zen amplifier
Hello everyone.
I made a BOZ preamp, I'm very satisfied with the performance, and now I want to make a ZEN amplifier, to pair it with the BOZ.
I ask anyone who can answer me which version of the ZEN amplifier you suggest to me, because I saw on the Passdiy website that there are nine versions.
I want to realize the ZEN because a friend of mine has created AMP CAMP AMP, and I was very impressed by the beautiful tonal quality, in my opinion even better than an Aleph 5 that also owns my own friend.
Many thanks for any answers.
Greetings, passionate friends!
Hello everyone.
I apologize a lot .... I copied the translation of my first post .. !!
Tanks mr.Pass. She is always very kind and helpful.
I apologize, I know I'll probably ask a lot, but I wanted to ask you some suggestions on nutrition. Currently on my friend's ACA there is a double capacitor 22000uf per channel, because only one has sometimes proved a little insufficient for certain orchestral peaks and fullness.
I wanted to ask you if you think this feed is good or different values, and we also tried some 100uf capacitors as a bypass of 22000uf, improving the exhaust speed and consequently the damping. I ask her if all this is good or there is some other solution that I could try for food.
thank you very much
the ACA in question is realized with that modification with 24V Power supply and additional 2.2kohm resistance on the two pins of the ZTX450, with 11.5V bias.
I say this in case you need to know it
