How to choose VAS current
Old 5th December 2018, 09:04 PM   #21
JeffYoung is offline JeffYoung  Ireland
JeffYoung's Avatar
On the double-BJT CCSs employed for the LTP and the VAS, I've seen them with the second leg taken to ground, and with the second leg taken to -V (as in the above drawings).
Are there advantages to either, or are they equivalent?
Old 5th December 2018, 09:08 PM   #22
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
pretty much same thing , if well filtered
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 5th December 2018, 09:54 PM   #23
JeffYoung's Avatar
Thanks, ZM.
I ran into an interesting limit for the VAS current. Increasing the current requires increasing the LTP resistor to maintain a 0 DC offset. However, at some point the voltage drop over the LTP resistor starts to eat into your swing and clip the amplifier.
Old 5th December 2018, 10:21 PM   #24
Itsmee is offline Itsmee  England
Itsmee's Avatar
Originally Posted by JeffYoung View Post
...with the second leg taken to ground, and with the second leg taken to -V...
It's only a personal opinion, so worth nothing.
I avoid connecting things to ground, idealy there should be no DC current flow on the 0V rail; the only current flow should be the input signal current, the output AC current should be returned to the PSU where it came from.
How to choose VAS currentHide this!Advertise here!
Watt ratings on amps. High current vs low current Richard_James Solid State 11 22nd February 2017 07:41 AM
Krell Current Audio Signal Transmission C.A.S.T. - Current mode Technology = CMT tiefbassuebertr Solid State 7 7th April 2012 01:12 AM
Hall-effect current sensor for output stage over-current protection panson_hk Solid State 4 6th September 2011 04:07 PM
About loadline again, how to choose load and current ervinl Tubes / Valves 3 24th August 2010 07:36 AM
trade off higher HT current for lower filament current ? Bigun Tubes / Valves 8 28th June 2010 12:10 AM
