Balanced Monoblock F4s with very high Bias
Old 4th December 2018, 03:07 PM   #11
syracuze is offline syracuze  United Kingdom
They are 6 ohm nominal, probably going down to 4ohm min.
Though, I would love these amps to play well with potentially more demanding loads just in case I change my speakers in the future.
More important; I remember reading BA3 and F4 being subjectively more authoritative (3 mosfet pair output stages) compared to F5 with only 1 pair, so I donít want to loose that aspect
Old 4th December 2018, 03:23 PM   #12
JeffYoung is offline JeffYoung  Ireland
JeffYoung's Avatar
With 23V rails you can only make use of about 5.5A into 4ohm. And even if you do run out of current drive this output stage will just drop into class AB rather than clip like a single-ended output would.
Beyond that I think you're just burning bias to generate heat to lower distortion. How fewer devices running at the same temperature will affect that I haven't a clue.
Old 4th December 2018, 03:48 PM   #13
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Originally Posted by syracuze View Post
Thoughts?
good luck finding a mate for IRFP150
good for one sex mosfets in output ( see Babelfish J thread) , but problematic for complementary ...... because there is no complementary , easily available
at least to my knowledge
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 4th December 2018, 05:49 PM   #14
Yeah, now I get it.
Back to old plan then..
Old 4th December 2018, 05:59 PM   #15
That is very true. I am very tempted with my theoretical 0.0006% distortion calculation in the very first post of the thread.
Old 4th December 2018, 06:33 PM   #16
indra1 is online now indra1  Indonesia
Only a few gifted people can discern distortion lower than 0.01%.
Old 5th December 2018, 05:14 AM   #17
I will see whether I am gifted enough
In all fairness, this is more of technically amazing case for the engineer inside me that I would love to figure out more.
No intentions to go for a distortion vs sound quality debate..
Old 5th December 2018, 11:15 AM   #18
JeffYoung's Avatar
This is DIY. Because it's technically interesting, or aesthetically pleasing, or a challenge, or oddball, or anything else that floats your boat are valid reasons to build. There's no requirement that everything be about sound.
(Not to refute Indra1's post, as the info is interesting. Just sayin'.)
Old 5th December 2018, 11:34 AM   #19
Yes, the uber important aspect of diy for me is the fun part.
Old 5th December 2018, 12:37 PM   #20
Very well said
100% agree!
Balanced Monoblock F4s with very high BiasHide this!Advertise here!
To Bias High, or not to Bias High... High Bias advantages in audio quality murillollirum Pass Labs 15 29th November 2018 06:25 PM
F5 DC High, Bias Low vdi_nenna Pass Labs 9 5th March 2016 01:04 AM
Please Help with Sound Valves M40 Monoblock Bias Adjustment Procedure!!! mq1688 Tubes / Valves 2 6th April 2013 06:14 AM
High bias class D sendler Class D 42 18th September 2010 01:41 PM
how high to bias? eLarson Pass Labs 2 10th November 2002 02:00 PM
