Aleph 5 based on BrianGT boards
Old 30th October 2018, 01:11 PM   #1
Nohabla is offline Nohabla  Norway
Send a message via AIM to Nohabla Send a message via MSN to Nohabla Send a message via Yahoo to Nohabla
Default Aleph 5 based on BrianGT boards
A long time ago i bought one set of aleph boards from Chipamp. I am now in the process of finishing them.
I have populated the boards as per the "Brians PCB Aleph - parts list" see attachment. I cannot remember where i got the parts list, perhaps from Chipamp.com before it closed..
It is a dual mono config with 2x25vac Toriods.
These are my findings when power voltage is +/-34 vdc from PS:
The output transistors does not heat up, just 2,2mv across R40 and even less on R39.
Q1, 2, 3 does heat up.
Voltage over z5 = 9V
Voltage over R8 = 5,2V
Voltage over R18 =3,3V
Q5 Gate to source =1,6mV
DC on output = 96mV
Any thoughts?
Appreciate all input
Old 30th October 2018, 02:19 PM   #2
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
schm, pics
pretty please
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 30th October 2018, 02:19 PM   #3
Dennis Hui is offline Dennis Hui  Canada
Hoopy Frood
Can you link/post a schematics for your board?
Edit: Mighty Zen Mod beat me to it.
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 30th October 2018, 02:53 PM   #4
Her's a schematic i picked up in another thread and pics.
Thanks for looking
Old 30th October 2018, 07:31 PM   #5
Hoopy Frood
Your voltage across R18 looks low. Are your Q1, Q3 IRF9610 devices matched?
- NP 2002
Old 30th October 2018, 09:18 PM   #6
Yes they are matched, or at least supposed to be, but perhaps i have managed to mix them up. I will take them out and do a rematching.
Does the BOM look right to you, for a A5?
Old 8th November 2018, 10:05 PM   #7
The input 9610's (Q1-3) and even the ztx450 (Q4-5) are matched. Both cards shows the same values under test. I have populated the cards as per the BOM posted.
If there is an error i must have made it on both cards.
I have checked the cards and it looks like the parts are installed in the right places
Any sugestions to what to look for?
Old 8th November 2018, 10:26 PM   #8
Zen Mod's Avatar
3 wires going to lower group of mosfets , but 4 wires going to upper group of mosfets ?
that additional is sense for Aleph CCS
Old 8th November 2018, 10:41 PM   #9
Bfpca is offline Bfpca  Canada
I just looked up the Vgs for a batch of 9610s I matched for a Group buy. 3.8volts would be pretty typical for. Looks like 23.5ma total current but only 8.4m across r18. 3.8volts is not enough to turn on the output fet. I see a lot of resistors are TBD. Do you have the recommended values in place? If you can’t find any problems you could try a 1k pot in place of R18. Start with it at 0 ohms and adjust it for the correct bias current.
Old 8th November 2018, 10:45 PM   #10
4 wirres goes to each side, the black was probably hard to see in the first pic's.
Aleph 5 based on BrianGT boardsHide this!Advertise here!
Gainclone building thread based on BrianGT's boards meat Chip Amps 752 8th August 2004 07:25 AM
Copyright ©1999-2019 diyAudio
