Babelfish M25, SissySIT - general building tips and tricks
Old 13th May 2019, 02:28 PM   #841
Juntuin is offline Juntuin  Finland
Well, there is working regulator now, confirmed with dmm. But same symptoms and not working. Pcb is starting to look like s**t because of resoldering
Old 13th May 2019, 02:36 PM   #842
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
trimpot on 0?
what voltage is between pins 1 and 2 of opto?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 13th May 2019, 02:43 PM   #843
Zen Mod's Avatar
btw. if mosfet gone dodo , check gate resistor , also resistors from rails to both gates
Old 13th May 2019, 04:31 PM   #844
Originally Posted by Zen Mod View Post
trimpot on 0?
Trimpot 0, altought it seems that it's position is irrelevant right now
Pin 1 is dot marked and 2 just next to it? Somethin like 1.2mV only there..
Old 13th May 2019, 04:40 PM   #845
Zen Mod's Avatar
each THF chip is outputting ( at zero Iq) something as Ub/2 , which is 2V5, ref. to GND
so , you need to have something as that on both R16 and R17 , sides to THF chips
than that's summed through these two resistors and taken further through R15 and P1
RS is 1K6 , shunting optodiode
VR1 is there just in case , as optoled guardian , but not really necessary
all that easiest to check without mosfets connected to pcb
though , it's hard to invent any scenario what happened , if first 7805 was Dodo , pretty much nothing else could go south , except output mosfets , and even that mostly because you weren't monitoring Iq critically as it was needed
compare whatever you can think of , unpowered, with functional channel
I'm here , hope we'll figure out together what's wrong
Old 13th May 2019, 05:08 PM   #846
R16 and R17 shows 0v, working channel gives 2,5V just as intented.
Old 13th May 2019, 05:56 PM   #847
Zen Mod's Avatar
trace with buzzer test ( so unpowered) , have you 5V to THF chips ?
also check is there GND to chips
if both yes , we have scenario - 7805 goes berserk , dodo THF chips because of overvoltage , dodo 7805
Old 13th May 2019, 06:37 PM   #848
Unfortunately yes to both
Old 13th May 2019, 07:24 PM   #849
Zen Mod's Avatar
send me an e-mail , we'll solve that
unfortunately , not today, not tomorrow , as you would like it most ....... and me too
Babelfish M25, SissySIT - general building tips and tricksHide this!Advertise here!
3D Modeling Tips and Tricks Patrick Bateman Multi-Way 13 14th March 2019 02:58 AM
PCB tips and tricks - Part 4 AndersHa Construction Tips 5 28th March 2016 11:26 PM
How To Solder Tips and Tricks Eddiegnz1 Tubes / Valves 21 20th December 2013 09:52 AM
Tube Tips/Tricks for beginners SamK2012 Tubes / Valves 10 19th November 2012 12:12 PM
Couple of tips/tricks peace brainerd Everything Else 0 10th April 2006 03:57 PM
Copyright ©1999-2019 diyAudio
