Babelfish M25, SissySIT - general building tips and tricks
Old 5th November 2018, 12:51 PM   #61
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
no need to re-check bias
normal behavior
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 5th November 2018, 07:22 PM   #62
Zen Mod's Avatar
Default some input xformer trickery
as already mentioned - with Cinemags there is some trickery necessary , to put them on pcbs
pins 1 and 2 are closer than other ones , so you know which pin 1 is - red dot on pictures
cut pins 1 , 6 , 7 and 12 , then you can mount Cinemags on pcb ; as you can see , on both channels pin 1 is near pcb edge
also pics of Edcors , Cheapskate Champions (one of cases where article is cheaper than shipping) - they're oriented with 180deg difference between channels ; pinout orientation pretty clear and straightforward , so no biggie there
Old 5th November 2018, 08:49 PM   #63
noelectrix is offline noelectrix  Europe
noelectrix's Avatar
Sissy does not like me
Problem with right channel:
This time setting Iq for buffer was almost straight forward. I just didnt get offset to zero and had to increase Iq to 22mA. Trick could be to increase upper R27 to have more headroom?
Then inserted JP, but turning on Iq pot did increased (U over R0.1) from around 4mV to just 5.6 mV to the end of pot, offset increased to almost 15 Volts.
Got me a bottle of wine to the studio to celebrate stereo this night, but this must wait (stereo, not wine).
Will of course recheck da hole thing tomorrow. Its really not that i watch series while stuffing PCBs, but this time im troublemaker.
Its late ZM, im happy for your thoughts in time : )
best
st
Old 5th November 2018, 09:06 PM   #64
Zen Mod's Avatar
well , troublemaker or not , I'm sure you'll find what's the culprit
it could help if you post some pictures , if you don't find it straight away in the morning or so
regarding source resistance .... I did check about dozen or so JFet groups and in all cases 27R ll 100R pot combo was adequate ..... but it seems that switch to 39R ll 100R pot will cover all possible Idss cases
I did some editing of post #1 , will proceed .....
Old 5th November 2018, 09:18 PM   #65
noelectrix's Avatar
ill do meditation on PCB tomorrow, either i come back with bad joke or pictures : )
tnx!
Old 5th November 2018, 09:23 PM   #66
Zen Mod's Avatar
dunno did you got Babelfish M25 or straight SissySIT package ........ so polarity (type) of mosfet is important ..... same as proper orientation of 7805 - they aren't mounted same on L vs. R channel
Old 5th November 2018, 09:29 PM   #67
noelectrix's Avatar
i made that supernice cableends i saw in your pics, from soft wire with hard wire end, i used laquered 1,4mm, i of course sanded
them but they seem to be cold (soldered) even if solderpoint looks nice,
thats work for now : )
Old 5th November 2018, 09:39 PM   #68
Zen Mod's Avatar
explain , what you mean - which cable ends I made ?
those shown in this very thread are nothing else than regular cables stripped on ends little longer , then covered with heatshrink - simply because I hate to see even slightly melting cable isolation ....... heatshrink is just even more shrinking , and still looks nice
Old 5th November 2018, 09:46 PM   #69
noelectrix's Avatar
ah, the i saw it different, i really hate to fix 1,5mm cable in tiny holes, so i took a superfine "Lize" from a cable, wound a hardwire peace at the end of the cable and soldered them together, sound comlicated or no good, but i show pics then, i like it
Old 5th November 2018, 09:50 PM   #70
Zen Mod's Avatar
aha , I got it
you did same as I did on Papa's Koan M2 , pics in my blog ........ and probably everywhere
tip: for thick wires , I'm always using screwdriver-like solder tip , around 8mm long edge , temp. set at 380-400C
Papa’s Koan (M)2 , an amp for living room | Zen Mod Blog
Babelfish M25, SissySIT - general building tips and tricksHide this!Advertise here!
3D Modeling Tips and Tricks Patrick Bateman Multi-Way 32 11th August 2019 08:41 AM
PCB tips and tricks - Part 4 AndersHa Construction Tips 5 28th March 2016 11:26 PM
How To Solder Tips and Tricks Eddiegnz1 Tubes / Valves 21 20th December 2013 09:52 AM
Tube Tips/Tricks for beginners SamK2012 Tubes / Valves 10 19th November 2012 12:12 PM
Couple of tips/tricks peace brainerd Everything Else 0 10th April 2006 03:57 PM
Copyright ©1999-2019 diyAudio
