Babelfish M25, SissySIT - general building tips and tricks
Old 28th March 2020, 11:10 AM   #1641
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 28th March 2020, 01:58 PM   #1642
flocchini is online now flocchini  United States
Well stated !!!
Old 28th March 2020, 06:19 PM   #1643
G600 is online now G600  France
Hi gents.
I'm simulating the boxing of my SissySIT, and need some advice.
My trannies are big boys, and fill almost all the width of my 4u 400 case.
How would you guys place the parts?
In the picture, the two white points beside the trannies show where I want to mount the Tokin. But doing so will put theit big legs at a few mm from the transformers.
Is it acceptable? Both for heat and noise?
Thanks!
Old 28th March 2020, 06:30 PM   #1644
Ben Mah is online now Ben Mah  Canada
If your case is high enough, you can stack the transformers.
Old 28th March 2020, 06:33 PM   #1645
Zen Mod's Avatar
acceptable
though , can you put big boyz stacked vertically ?
it's easy to drill one black core all the way, and use longer bolt
something as I did here , and even simpler - you don't have pots to care about isolation etc. : post #52 , Most Greedy Boy, of them all... or (there is no) DEFiSIT of Papa's Koans
that way , you'll have space for bridges at left and right of Donuts
Old 28th March 2020, 06:36 PM   #1646
Zen Mod's Avatar
also , use some spacers between lower frame L brackets and base plate , to allow some space for routing mains wires beneath
Old 28th March 2020, 06:50 PM   #1647
Here is a picture of my SissySIT with stacked Antek transformers. I purchased a length of threaded rod and cut it to size, with nuts at both ends to bolt the transformers in place.
Old 28th March 2020, 07:03 PM   #1648
Thanks!
I'll explore the stacking option.
ZM, I don't need to route the mains below the perforated baseplate.
I have FW like PSU boards, with a path for mains live and neutral, along with CL60. Looks pretty straightforward to provide mains to the transformers without any hassle.
Babelfish M25, SissySIT - general building tips and tricksHide this!Advertise here!
3D Modeling Tips and Tricks Patrick Bateman Multi-Way 44 25th February 2020 09:59 AM
PCB tips and tricks - Part 4 AndersHa Construction Tips 5 28th March 2016 11:26 PM
How To Solder Tips and Tricks Eddiegnz1 Tubes / Valves 21 20th December 2013 09:52 AM
Tube Tips/Tricks for beginners SamK2012 Tubes / Valves 10 19th November 2012 12:12 PM
Couple of tips/tricks peace brainerd Everything Else 0 10th April 2006 03:57 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
