Babelfish M25, SissySIT - general building tips and tricks
Old Today, 08:49 PM   #1341
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
never use less than 370C , with proper tip ....... and if you're soldering fat wire or something substantial , feel free to crank it all the way up , with intention that your soldering lasts as short you can manage
larger tip means much lesser temp hysteresys on very tip of ..... tip
so , better to use slightly fatter tip than slightly narrower
I have 2 solder stations on my bench , one equipped with 7mm chisel tip type for fat wires and mosfet legs , and second ( in fact that being first/main) with tiny tip .... which isn't at all tiny - not pen/needle sharp , but more like as tiny flat chisel - having flat part of some 0.7mm
that one doing all my SMD presoldering , using hot air only as final soldering operation
so , with that amount of heat , which you most probably are investing in your soldering- even with pads which on eye are staying intact , you're compromising their bond to pcb
so , think where you're doing it wrong
no problem if SIT is close to Donut - look at my builds
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Babelfish M25, SissySIT - general building tips and tricksHide this!Advertise here!
3D Modeling Tips and Tricks Patrick Bateman Multi-Way 35 28th August 2019 11:00 AM
PCB tips and tricks - Part 4 AndersHa Construction Tips 5 29th March 2016 12:26 AM
How To Solder Tips and Tricks Eddiegnz1 Tubes / Valves 21 20th December 2013 10:52 AM
Tube Tips/Tricks for beginners SamK2012 Tubes / Valves 10 19th November 2012 01:12 PM
Couple of tips/tricks peace brainerd Everything Else 0 10th April 2006 04:57 PM
Copyright ©1999-2019 diyAudio
