Babelfish M25, SissySIT - general building tips and tricks
Old 11th November 2019, 03:57 AM   #1331
twitchie is offline twitchie  Canada
Magic Smoke Liberator
Originally Posted by Juntuin View Post
Hmm, would it come with too much trouble to convert my M25 to SissySit SITís are already awaiting in my drawer.
For once time is not problem, since Iím unemployed very soon.
See Post #1 for both schematics for M25 and Sissysit.
You would be best checking yourself but what I can see:
M25 - D1, D2, D3 (no D4, D5)
Sissysit - remove D1 and D2 and install at D4 and D5
Reverse the direction of install for zeners - ZD1 and ZD2
Remove RS(R and L), P1 goes from 1K to 2K
R19 47K in M25, 36K in Sissysit (R18 stays 43K in both)
R15 270R in M25, 1K in Sissysit
Q3 device changes of course and don't forget the 100R resistor on the gate pin of the SIT.
Old 11th November 2019, 04:51 AM   #1332
rhthatcher is offline rhthatcher  United States
Looking for help.
Left channel board is alive and singing. Dead quiet on test speakers. And makes beautiful music.
Right channel board offset is not settling down as nice.
So I thought I would try the driver bias and live with more offset on test speakers.
Set 20mV on R8. Check.
JP to Gnd = 2.7V. Turn increase R7 and voltage goes up. What could be the problem? It is NOT acting like the other channel. Need some insight. Hope the board pix are helpful.
Old 11th November 2019, 05:56 AM   #1333
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
be sure that you're measuring on proper pin of JP , vs. GND
one pin is looking at xformer , another one to buffer output
I'm damn sleepy right now, we arrived at SR less than 2 hours ago , so I'll post nice pic with marked pins for setting buffer DC offset , for both channels
good night ......
btw. your soldering could be better
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 11th November 2019, 06:45 PM   #1334
Juntuin is offline Juntuin  Finland
Thanks, nicely summed up gotta double check, but Iím usually quite blind when modifying circuit.
Old 12th November 2019, 12:50 AM   #1335
cal3713 is offline cal3713
Originally Posted by rhthatcher View Post
Looking for help.
As ZM pointed out, you've got quite a few open through-holes in the soldering. My first build was an F4 and I didn't get the solder to flow fully through the holes, it created a lot of unstable oscillation behavior... got things steady walked away for a second and turned around to see smoke. Things calmed down when I re-soldered everything so that the solder went completely through the holes (and was filled on both sides)...
Old 12th November 2019, 08:00 PM   #1336
Reverse the direction of install for zener - ZD1 ONLY!!!
I made a mistake - ZD2 does not need to be reversed between M25 and Sissysit, only ZD1 is reversed.
Old 15th November 2019, 09:33 PM   #1337
I'm just returning from a biz trip. I'll have to fire up the soldering iron this weekend.
Babelfish M25, SissySIT - general building tips and tricksHide this!Advertise here!
3D Modeling Tips and Tricks Patrick Bateman Multi-Way 35 28th August 2019 11:00 AM
PCB tips and tricks - Part 4 AndersHa Construction Tips 5 29th March 2016 12:26 AM
How To Solder Tips and Tricks Eddiegnz1 Tubes / Valves 21 20th December 2013 10:52 AM
Tube Tips/Tricks for beginners SamK2012 Tubes / Valves 10 19th November 2012 01:12 PM
Couple of tips/tricks peace brainerd Everything Else 0 10th April 2006 04:57 PM
Copyright ©1999-2019 diyAudio
