Babelfish M25, SissySIT - general building tips and tricks
Old 9th October 2019, 07:35 AM   #1241
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
few things - don't waste your time with WCF; I made it as option , but consensus by now is that is too much of good thing ...... interesting for Babelfish M25 , simply because of inherently much lower THD than SissySIT , so adding some sugar can be good in some circumstances
while with SissySIT , in most cases it is too much
regarding F4 - as I'm always saying - there is no comparison between amps really ...... but comparison of some other amp vs. preamp driving a F4 ...... simply because F4 is always just forwarding preamp's character , nothing more
and yes - that NP of yours ......... my Pa is eating him for breakfast , every day
NP is fun , as I heard , but Pa is much funnier
edit: luckily we had few more eyes and brains , to help with your adventure ; mine would suffice eventually , but it was faster with help of Greedy Boyz
and ....... don't waste your time with serious listening ...... just enjoy ; I know that you must (and you will ) realize the same , but now you made one of the best small amps money can buy ..... either commercially done or as DIY
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 9th October 2019, 12:04 PM   #1242
ItsAllInMyHead is offline ItsAllInMyHead  United States
Originally Posted by cal3713 View Post
Screws are in and music is on in the big system.
Congratulations!
Old 9th October 2019, 05:17 PM   #1243
cal3713 is offline cal3713
As always, thanks for the input.
I feel really privileged to have mono-block F4s & SissySITS both just hanging out ready to make beautiful music. Plenty of frustration in the build process, but also lots of enjoyment and learning. And I don't need a large amp, so I'll just consider that I have two of the best available...
Old 10th October 2019, 06:07 PM   #1244
sontero is offline sontero  Italy
sontero's Avatar
you have one....best: SissySit
Old 18th October 2019, 09:59 PM   #1245
asanden is offline asanden  Netherlands
Hi, finally some time to make an attempt to get the sissysit up.
Pcb’s are done, cinemag HQ trafo
Will re-use my two identical M2 amps as dual channel mounted monoblocks, M2 and sissysit per chassis. I shall power one channel per chassis.
Sissy question...
I have 4 Harris p9240 unused; in the M2 it was advised to use them, got them from Teabag, but I used Toshiba’s, so 4 left over, could use 2 of them.
Would they improve the amp, and if so; need to be measured for Vgs?
Old 18th October 2019, 10:22 PM   #1246
Zen Mod's Avatar
o yeah , Harris welcomed
no need for any measurements ...... at least that was my experience with P Harris - they were all well more than 4V of Ugs , for I/V area of interest
Old 18th October 2019, 10:47 PM   #1247
Thx, will do that
Old 23rd October 2019, 11:41 AM   #1248
BRN is offline BRN  United States
I have a couple of 20v 400va transformers and wanted to know if I could use them with a CRC power supply in the SissySIT? Not sure if it would be to much voltage.
Old 23rd October 2019, 12:05 PM   #1249
Zen Mod's Avatar
it'll work for sure , if you have proper set of SITs , measured at 24V/2A , with Ugs no more than 3V7 , when hot
possibility of slight increase of R in CRC , vs. my fave value of 0R1
say two paralleled WW of 0R47 , which will give you 0R235 , then you're shooting for 420mV across , when setting Iq (1A8)
if you abandon idea of using these, from any reason , feel free to send them to OPLDF
Old 23rd October 2019, 03:33 PM   #1250
Ylab is offline Ylab
Am I the only one here waiting for the cinemag transformers to arrive?! Paid for 2 months ago and no news since ! Board are fully stuffed and waiting patiently..
Babelfish M25, SissySIT - general building tips and tricksHide this!Advertise here!
3D Modeling Tips and Tricks Patrick Bateman Multi-Way 35 28th August 2019 11:00 AM
PCB tips and tricks - Part 4 AndersHa Construction Tips 5 29th March 2016 12:26 AM
How To Solder Tips and Tricks Eddiegnz1 Tubes / Valves 21 20th December 2013 10:52 AM
Tube Tips/Tricks for beginners SamK2012 Tubes / Valves 10 19th November 2012 01:12 PM
Couple of tips/tricks peace brainerd Everything Else 0 10th April 2006 04:57 PM
Copyright ©1999-2019 diyAudio
