Wayne's BA 2018 linestage
Old 11th February 2019, 03:12 AM   #211
BDP is offline BDP  United States
Originally Posted by labjr View Post
Do the JFEts need to be matched?
See post #132. You can easily check them yourself.
BDP
Old 11th February 2019, 05:33 PM   #212
Russellc is offline Russellc  United States
Originally Posted by 6L6 View Post
You need the K170s, and yes, there is.
Hmm. Seems like we should make use of them. Other than being SMT, why aren't people using these given shortages of regular k170/j74 pieces?
Forgive the off topic, but I'm surprised!
Russellc
Pass B-1 preamp, Pass BA3 preamp, Pass F-5 Amp, Pass F-6 Amp, Pass BA-3 Amp, Pass M-2 amp, Pass Aleph J amp, Pass Pearl 2 Phono pre Tekton Enzo, Altec A7, Econowave JBL 2235H & B&C CD
Old 11th February 2019, 05:55 PM   #213
mpmarino is offline mpmarino  United States
mpmarino's Avatar
If one were to stack two circuits for balanced operation.....
Could it effectively convert Bal to SE, or visa versa?
If so, would you have to ground the balanced negative on the SE side?
Crazy Yankee.
Old 11th February 2019, 06:38 PM   #214
DougL is offline DougL  United States
I watched the Utube presentation of the BA 2018 Line stage.
I learned a lot going through the presentation and schematic.
My question is application related. What was the BA 2018 designed to drive?
I am guessing F4 / MOFO type circuits.
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 11th February 2019, 09:32 PM   #215
wayne is offline wayne  United States
Auburn
wayne's Avatar
It wasn't really designed to drive anything in particular more of just a experiment. It will drive quite a few things though especially with the bigger outputs.
wizards assistant
Old 11th February 2019, 10:51 PM   #216
gary s is offline gary s  Australia
Wayne, if one were to use the bigger output transistors, what other components would need to be changed and what would be their new values?
Thanks in advance.
Old 11th February 2019, 11:09 PM   #217
Auburn
wayne's Avatar
Change the 27 Ohm emitter resistors to 15 Ohms and double the output current.
wizards assistant
Old 11th February 2019, 11:14 PM   #218
Thanks for the very quick reply Wayne.
Old 12th February 2019, 12:19 AM   #219
Dennis Hui is online now Dennis Hui  Canada
Hoopy Frood
I worked on mine over the weekend using the kit kindly supplied by 6L6.
It's not quite done yet since I have yet to test it. I hope to be able to
do that this coming weekend.
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 12th February 2019, 12:38 AM   #220
6L6 is offline 6L6  United States
6L6's Avatar
Looks good! Test, listen, enjoy, and report back.
Wayne's BA 2018 linestageHide this!Advertise here!
Wayne Parham's 2pi Towers cfishbowl Multi-Way 8 3rd December 2016 02:38 PM
Looking for a DIY repair guy near Toledo or Ft. Wayne crbirdx Tubes / Valves 0 15th June 2012 03:45 AM
Wayne's 12Pi sub scameron78 Subwoofers 375 5th January 2012 10:11 PM
Copyright ©1999-2019 diyAudio
