Wayne's BA 2018 linestage
Old 22nd March 2020, 07:13 PM   #1001
6L6 is offline 6L6  United States
6L6's Avatar
Ah! The photo in the data sheet has "1 2 3" but the drawing has "1 2 C". So yes, C is 3.
Usually the chassis ground is at the PSU, but that might not work with Silent Switcher... need to see your entire wiring diagram.
Old 22nd March 2020, 07:19 PM   #1002
manniraj is offline manniraj  India
Hmm ok let me put down my wiring with the power amp and preamp in a single chassis and how I did the wiring to showcase if this works. As I think I get lot of hum which seems to be ground loop issue
Old 23rd March 2020, 07:57 AM   #1003
Apart from checking the DC offset being closer to the 0mV on each of the mono boards outputs, what else should I check for the bias any other things on the preamp.
Old 23rd March 2020, 06:36 PM   #1004
Any pointers guys, sorry I looked around in the thread but could not find instructions on the PDF document as well.
thanks
Old 23rd March 2020, 08:28 PM   #1005
6L6's Avatar
Twist the pot to make the dc offset at the output zero or as close as you can get it. That’s it.
Old 23rd March 2020, 08:45 PM   #1006
Twist the pot to make the dc offset at the output zero or as close as you can get it. Thatís it.
Thanks Jim
Old 24th March 2020, 08:45 PM   #1007
The connections that you suggested work beautifully. There was hum initially then I connected one of the output grounds to the chassis and the hum disappeared completely and dead silent even on headphones
Thanks Jim again.
Old Yesterday, 01:03 PM   #1008
Gaz2613 is offline Gaz2613  United Kingdom
Gaz2613's Avatar
I was told you guys wanted a PSU for this bad boy! Here you go!
Check out my site: www.audiosy.net - Audio Reviews and DIY (Still a Work In Progress)
Old Yesterday, 01:44 PM   #1009
Centurion53 is offline Centurion53  United States
Is this a commercially available supply or of your own design?
Old Yesterday, 01:48 PM   #1010
6L6's Avatar
It’s essentially the WHAMMY PSU section put on it’s own PCB. Looks great!
Wayne's BA 2018 linestageHide this!Advertise here!
Wayne Parham's 2pi Towers cfishbowl Multi-Way 8 3rd December 2016 01:38 PM
Looking for a DIY repair guy near Toledo or Ft. Wayne crbirdx Tubes / Valves 0 15th June 2012 02:45 AM
Wayne's 12Pi sub scameron78 Subwoofers 375 5th January 2012 09:11 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
