NJFETs for Source Follower Applications
Old 25th October 2018, 01:55 PM   #11
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
The HD looks to have approximately the same slope for all, 6dB/10dB for 2nd's and 3rd's with doubling. Any thoughts on a small source resistor and trim on the current source for 0V output?
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 25th October 2018, 02:29 PM   #12
EUVL is offline EUVL  Europe
Post #1, "Each of the N-JFET pairs used in the testing was matched to <10μA in Idss."
So DC was < 1mV in all cases.
But yes, if one can measure upfront and use the JFET with higher Idss for the CCS, a small source resistor will allow easy trimming of DC offset.
I normally do not use source resistor for the upper JFET.
Somewhere I read before it is supposed to create more H3.
2SK117 can still be bought, 2SK209 for sure.
So no need to be desperate, for now at least.
Patrick
xen-audio.com
Old 25th October 2018, 03:25 PM   #13
Just curious, since the numbers imply a possible simple mathematical rule might underlie this.
Old 25th October 2018, 03:33 PM   #14
Do you have an explanation for the increase in H2 but significant decrease in H3 for the GR grade ?
Patrick
xen-audio.com
Old 25th October 2018, 03:38 PM   #15
Patrick
Looking into it.
Old 25th October 2018, 03:48 PM   #16
obh is offline obh  Norway
If 2sk2145 used as a single device then expect voltage noise reduced by 1.4 (about -3dB)
relative to 2SK209GR? Would relation H2/H3 be same?
Old 25th October 2018, 05:22 PM   #17
No, because the load now appear as 20k for each FET.
So both H2 and H3 will drop, probably to K170 levels.
Patrick
xen-audio.com
Old 25th October 2018, 05:28 PM   #18
Note that 2SK2145 is NOT specified as a matched pair as e.g. 2SK389.
There is no specification on the datasheet as to how well the match is.
In my experience can be as bad as > 5% in Idss.
You can read Samual Groner's article on his Low Noise Amplifier regarding the effects of mismatch in paralleling devices.
In that amplifier, he was using 8x BF862's, but from a noise instead of distortion perspective.
Patrick
xen-audio.com
Old 25th October 2018, 07:26 PM   #19
Originally Posted by scott wurcer View Post
Looking into it.
Nothing conclusive, seems that secondary effects come into play at these levels. -90 or so dB is pretty good.
Old 25th October 2018, 08:24 PM   #20
Patrick
xen-audio.com
NJFETs for Source Follower ApplicationsHide this!Advertise here!
Source follower VS white cathode follower hellokitty123 Tubes / Valves 12 27th April 2018 11:16 PM
Source follower and common source output stages slogan2112 Pass Labs 2 9th October 2008 08:19 PM
Aleph-type current source, but source follower this time tschrama Pass Labs 4 29th July 2005 12:55 PM
Source follower electret mike -> use with current source? capslock Solid State 1 28th February 2003 12:54 PM
Plate follower and applications tiroth Tubes / Valves 15 21st April 2002 08:15 PM
Copyright ©1999-2019 diyAudio
