To paint or not to paint - Heatsink Question
Old 11th October 2018, 02:35 PM   #31
alexberg is offline alexberg
alexberg's Avatar
Originally Posted by metalman View Post
Color of anodizing does matter as the emissivity varies with color. Similar variation in emissivity also occurs with paint colors.
At least everybody agrees that polishing does not help.
With all do respect, most colors in the table of yours have around 0.8. For instance correction pen provides rather accurate reading on FLIR being quite white (probably titanium oxide).
P.S. If it was an scientific paper I would of readily agree.
P.P.S. In respect to paint being the thermal barrier. Usually the specific power flow is small, like 1/3W per inch square so the paint conductivity does not matter that much.
P.P.P.S In industrial environment the proper fan usually suffice so I doubt that appropriate paper exist in non-space related field. Cheers
Old 11th October 2018, 02:43 PM   #32
JMFahey is online now JMFahey  Argentina
JMFahey's Avatar
Originally Posted by KatieandDad View Post
I've done some phoning around. I'd have to paint strip the sinks first. Then it would cost about 80 to have them anodized in black.
I might consider it as it apart at the moment with failed PSU caps.
Ouch!!!
In that case, leave as-is.
In any case, the main cooling effect is still convection, by a large margin, so having a minor variation in the secondary cooling effect is not worth worrying about.
IF you feel cooling is not enough, add a small fan.
Even if undervolted and not moving much air, just a gentle noiseless breeze, you will be *replacing* hot air with fresh one around the heatsinks a few times a minute, and that improves the situation considerably.
Any air flow is better than none.
I often add 12V PC type fans powered by rectified 6.3V filament voltage, so some 8V DC, "somewhere" in tube type Guitar amps.
I am not actually cooling *the tubes* themselves, plates are inside *vacuum* , real Thermos flasks, so they cool by pure Radiation and fan does not affect that, but ambient temperature in and around the chassis drops enough (even if still hot to the touch) to improve overall reliability.
On the contrary, your heatsinks will offer improved cooling.
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 11th October 2018, 07:37 PM   #33
Eric is online now Eric  United States
Eric's Avatar
Probably the easiest and most effective thing you can do with your chassis to promote cooling is to make sure there is air circulation through your chassis (which your chimney will certainly accomplish), and to lift the chassis so the bottom of the sinks are 25-30mm (minimum) above the surface the amp sits on.
Quick and dirty "legs" can be made from a hex head bolt and two nuts - the nuts sandwich the bottom plate of the amp and the shaft of the bolt gives you some clearance for improved air circulation. Put one set in each corner of the amp.
My DIY Basement Theater, Aleph-X Amps, Avro Open Baffle Speakers, LDR based BA-3 pre, Pearl II, highly modded Technics SL-1200, F4, M2, a40, several ACAs, FHXL, Tang Band 1772 bass-reflex
To paint or not to paint - Heatsink QuestionHide this!Advertise here!
Rockford DSM Heatsink Paint permo Car Audio 6 13th April 2018 11:33 AM
Really OT question about paint Conrad Hoffman The Lounge 14 22nd January 2008 08:28 AM
quick question regarding paint sqlkev Multi-Way 2 3rd July 2007 02:21 AM
Paint steel chassis with the "aluminum paint" used on wire fence? vax9000 Tubes / Valves 2 23rd July 2006 01:14 AM
Chassis and heatsink thermal paint arnach Everything Else 4 1st December 2002 01:49 AM
