To paint or not to paint - Heatsink Question
Old 10th October 2018, 04:41 PM   #21
Eric is offline Eric  United States
Eric's Avatar
I am going to experiment with this shortly - I have a few sinks that are natural aluminum and some of the same profile that are painted black vs brown.
I am planning to use an upcoming MoFo build (most simple- single sink, single transistor to mount) to compare various types of mounting interfaces (various silpads, mica&goop, Keratherm, Aluminum oxide ceramic, etc).
This will also give an opportunity to explore paint color vs raw aluminum. Still waiting on a few parts to arrive in the mail, but this should provide some interesting data.
My DIY Basement Theater, Aleph-X Amps, Avro Open Baffle Speakers, LDR based BA-3 pre, Pearl II, highly modded Technics SL-1200, F4, M2, Aleph-J, MoFo, a40, several ACAs, FHXL, Tang Band 1772 bass-reflex
Old 11th October 2018, 02:44 AM   #22
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
You sure they are *painted*?
Id guess they are anodized intead.
Which on aluminum is cheaper/faster/better/more uniform.
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 11th October 2018, 02:51 AM   #23
alexberg is offline alexberg
alexberg's Avatar
Color of the paint on anodized aluminum does NOT matter.
Old 11th October 2018, 02:56 AM   #24
metalman is offline metalman  Canada
metalman's Avatar
Color of anodizing does matter as the emissivity varies with color. Similar variation in emissivity also occurs with paint colors.
File Type: jpeg EAB25793-DADB-4D49-9960-2E8F853111E4.jpeg (447.4 KB, 134 views)
Darn career gets in the way of my audio addiction!
Old 11th October 2018, 08:47 AM   #25
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Is that a philosophical point you are making?
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 11th October 2018, 08:58 AM   #26
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
They are definitely painted.
Old 11th October 2018, 09:01 AM   #27
avtech23 is offline avtech23  Australia
Certifiably addicted to DIY.
avtech23's Avatar
Originally Posted by vdi_nenna View Post
How to anodize without battery acid.
Acid vs non-acid process results look the same in photo.
Anodizing and dyeing aluminum without battery acid... - Observations
Thanks for that link. Very useful!
The ever growing project list.. :NAP140 Clone, NAD 3020i & 3225PE, JLH1969, TDA2050, Fender 5F2A Princeton, NE5532 Preamp | : VSQC Phunk Style, Retro 50W | : Apex AX-14 | SHPA | TGM-10 | TDA7265 (Last in line)...maybe
Old 11th October 2018, 10:32 AM   #28
rookakoma is offline rookakoma  Hungary
rookakoma's Avatar
The emissivity of clear anodized is 0.76 to 0.84, close to black (0.82-0.86)
and the plain is just 0.04?
Is that correct?
F5 Turbo
Old 11th October 2018, 11:16 AM   #29
I've done some phoning around. I'd have to paint strip the sinks first. Then it would cost about 80 to have them anodized in black.
I might consider it as it apart at the moment with failed PSU caps.
Old 11th October 2018, 03:10 PM   #30
alexberg's Avatar
Who knows. Not cheery picking for sure.
To paint or not to paint - Heatsink QuestionHide this!Advertise here!
Rockford DSM Heatsink Paint permo Car Audio 6 13th April 2018 12:33 PM
Really OT question about paint Conrad Hoffman The Lounge 14 22nd January 2008 09:28 AM
quick question regarding paint sqlkev Multi-Way 2 3rd July 2007 03:21 AM
Paint steel chassis with the "aluminum paint" used on wire fence? vax9000 Tubes / Valves 2 23rd July 2006 02:14 AM
Chassis and heatsink thermal paint arnach Everything Else 4 1st December 2002 02:49 AM
