To paint or not to paint - Heatsink Question
Old 9th October 2018, 02:38 PM   #11
Soundhappy is offline Soundhappy  France
Soundhappy's Avatar
ShopBuilt - How to Anodize Aluminum!
Quality work
class A amplifiers with full range speakers
sings like angels in heaven
Old 9th October 2018, 03:07 PM   #12
oreo382 is offline oreo382  Canada
Paint is better,just don't paint the area where the transistor/mosfet is mounted.
Old 9th October 2018, 03:20 PM   #13
metalman is offline metalman  Canada
metalman's Avatar
As a practicing professional materials engineer, let me weigh in.
From a purely thermal point of view, best option is to apply a thin coat of a matte black paint. Stay away from glossy finishes.
Heatsinks are overwhelmingly convective as far as heat transfer goes, so it won’t make a big difference, but a matte black paint will have a much higher emissivity than the “silver” aluminum for radiative transfer. A thin coat of paint will only create a negligible effect in terms of insulating against conductive heat transfer.
Terry
Darn career gets in the way of my audio addiction!
Old 9th October 2018, 03:21 PM   #14
rookakoma is offline rookakoma  Hungary
rookakoma's Avatar
Under natural convection conditions, the performance of a heatsink with a black surface will be 6% to 8% better than that with a plain or bright surface. However, this differential disappears under forced air conditions.
source:
http://robots.freehostia.com/Heatsinks/Heatsinks.html
or:
https://www.mouser.com/pdfDocs/Ohmit...sink_Guide.pdf
Scott has right:
Heatsinks work more by convection than radiation so colour isn't such a large issue as surface area, orientation of fins and good air flow
F5 Turbo
Old 9th October 2018, 03:58 PM   #15
alexberg is offline alexberg
alexberg's Avatar
Black body emits into a vaccum about 5.76W @ 100K per meter square. Having heatsink @ 330K it will change to 690 W. Be aware that finning does not help. Assuming two sides of 4" high 19" unit to be a total heatsink projection area we'll get 0.1 m^2 thus 69W. Emissivity of an anodized aluminum is quite good.
Old 9th October 2018, 09:42 PM   #16
Bare is offline Bare  Canada
Nonsense. Paint the heat sinks .. thinly tho.. with flat black paint.
Ideally with parts still as rough textured castings
Heat dissipates faster as result, researched, documented and proven.. decades ago.
This from a misspent youth fielding Yamaha TZ Racers for the Yama factory.
Lotsa testings by industrious Yama Engineers revealed that the thin black paint was best for purpose.
IE; keeping reciprocating parts running at ~11,000 rpms with a Heat critical 0.008 " running clearance ..from seizing solid.. at 180 mph.
Myopic beliefs aside, this was a serious issue, long ago dealt with.
As for the critical temps of a couple of $$ Output device.. Really ??
Old 9th October 2018, 09:49 PM   #17
Btsd is offline Btsd  Australia
I go with what look I want.
Bottom one (aleph J) black heatsinks with polished edges.
Second up (aleph mini) fully sandblasted heatsinks with polish edges.
Everything else I have built in the Aleph set is fully sandblasted.
Old 9th October 2018, 10:28 PM   #18
res07njc is offline res07njc  United States
It's true, that paint is an insulator. Electrical insulator!
I've had success mounting parts straight to the painted surface. In other words, no mica, just grease. One mans "loss", another's gain.
Providing the aluminum was prepped smooth and the active device has no particular burrs or sharpies. So far just TO-247 parts.
I've gone so far as the contemplate taping off natural aluminum just for the area where the mosfets are going to be mounted!
Old 10th October 2018, 02:00 AM   #19
vdi_nenna is online now vdi_nenna  United States
vdi_nenna's Avatar
To paint or not to paint - Heatsink Question Send a message via Yahoo to vdi_nenna
How to anodize without battery acid.
Acid vs non-acid process results look the same in photo.
Anodizing and dyeing aluminum without battery acid... - Observations
I build, therefore I am.
Old 10th October 2018, 11:12 AM   #20
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
Thank you guys. The heatsinks are already painted in matt black. I'll leave them alone.
To paint or not to paint - Heatsink QuestionHide this!Advertise here!
Rockford DSM Heatsink Paint permo Car Audio 6 13th April 2018 12:33 PM
Really OT question about paint Conrad Hoffman The Lounge 14 22nd January 2008 09:28 AM
quick question regarding paint sqlkev Multi-Way 2 3rd July 2007 03:21 AM
Paint steel chassis with the "aluminum paint" used on wire fence? vax9000 Tubes / Valves 2 23rd July 2006 02:14 AM
Chassis and heatsink thermal paint arnach Everything Else 4 1st December 2002 02:49 AM
