How to use these huge caps in PSU for F5?
Old 10th October 2018, 02:58 AM   #11
gadut is offline gadut  Indonesia
gadut's Avatar
Originally Posted by AudioSan View Post
I would use a overkill transformer with those caps. And a 2x series connected CL60 based softstart that bypass the thermistors after a little while. Do not use a softstart with parallell connected CL60.
my scheme is that softstart before transformer, CL60 is on DC side. they serve different purpose
AD1865||DCB1||FW PSU||J2||M2||SIT L'Amp||Open Baffle
Old 10th October 2018, 03:44 AM   #12
Hikari1 is online now Hikari1  United States
Originally Posted by Hubba View Post
I've got my hands on some really huge 68000uF/40V caps, or rather four of them (may get an additional two), and I'm thinking about doing a PSU for my F5 using them as I kind of like the look of them.
However, my skills in the PSU domain are limited at best, so I would appreciate some help. Using the standard Pass F5 PSU schematic, is it possible to simply replace C1&C2, C3&C4...with one of the caps, or would that mess things up?
Thanks,
Fredrik
That’s totally fine to do, just put R (resistor) or L (choke) between the two caps. You won’t need more than a single cl60 most likely. I use 6x33,000uf with a single cl60. Be aware that the stud on that capacitor may be connected to ground and will need to be isolated.
Old 10th October 2018, 06:09 AM   #13
AudioSan is offline AudioSan  Norway
You are looking at the wrong CL60.
Old 10th October 2018, 08:52 AM   #14
Hubba is offline Hubba  Sweden
Smile Thank you for all the input!
Thank you all who has helped answering my questions, as well as pointing out potential problems.
I'm going for a standard CRC setup using in total 4 of the caps.
As some of you have pointed out the in rush current may be an issue, but I have a separate soft start Circuit (with 4xCL60 and a by pass relay) which takes care of that...
Once again, thank you all for valuable input!
Fredrik
Old 10th October 2018, 02:40 PM   #15
Fredrik
That is just the kind of softstart you never should use. They have parallell connected thermistors. two and two in parallell and the two couples are series connected. Or all 4 are in parallell.
Old 10th October 2018, 06:57 PM   #16
@AudioSan
Why is that a problem?
/Fredrik
Old 10th October 2018, 07:11 PM   #17
Thermistors change impedance with current draw. And current takes the path of least resistance. So you will get current hog on one of the thermistors (or two if the are two and two in parallell).
Old 10th October 2018, 07:27 PM   #18
ah, yes..ok
The thermistors are only in play for a couple of seconds, after that a relay closes and the transformer is fed from that path instead.
/F
Old 10th October 2018, 10:37 PM   #19
aspringv is offline aspringv  Australia
Hi Hubba, is it one of these by chance?
Just be aware that I think theres some pretty reasonable leakage current through this item. I used on on an aleph build and the led's on the amp boards would never quite go off... concerning enough that I unplugged it.
I should really open that guy up and do some checking actually!
Last edited by aspringv; 10th October 2018 at 10:38 PM. Reason: added pic for the lazy
Old 11th October 2018, 04:28 AM   #20
dazed2 is offline dazed2  Canada
No problem at all!
Go CRC
But I do think you need a slow charge circuit.
How to use these huge caps in PSU for F5?Hide this!Advertise here!
Rectifier caps; go for the huge ones? hansibull Power Supplies 3 26th December 2013 05:18 AM
HUGE LOT of caps coils resistors on ebay Mattyo5 Swap Meet 12 24th November 2008 01:58 PM
FS: 100vdc Caps--Huge Caps gengis Swap Meet 4 18th May 2005 09:20 PM
FS 6 packs of HUGE caps! glhs377 Swap Meet 1 17th January 2005 05:33 PM
Are huge DC blocking caps on Zen ok? Arx Pass Labs 13 3rd November 2003 08:38 PM
