I'm thinking about putting the PSU and the Amplifier in two different chassis for ventilation purposes.
Is it okay to have a long distance wire run between the rectifier and the amp?
Keep it all in one chassis, unless you want to go with monoblocks (two separate, mono amplifiers).
A separate power supply chassis won't help thermally.
@Rayma, I see what you're saying but In my application, my bedroom cabinet is pretty small with not a lot of area for heat to dissipate. So I was thinking I could put one pretty box under my Tv for aesthetics (The amplifier) and hide the PSU somewhere with good ventilation. I believe it would overheat or damage my furniture if I kept it in one box.
The power supply dissipation (diode blocks and resistors) is small compared to
that of the audio channels. Instead, I'd use a cooling fan on each heat sink,
or else turn down the bias until your placement changes, if it's only short term.
Got my words mixed up sorry. I meant the PSU under my TV and the amp somewhere else. Unfortunately its not short term Is it a bad idea or just not ideal?
I put together the BOM Digi-Key - Fast Add still unsure on the other values for the Input snubber resistor and Input snubber Capacitors. Im using a single Antek 4218. I'll do some reading but would like a second opinion before I order.
I would go with a single chassis. The audio boards/sinks are the biggest and hottest parts,
so the entire amp may just as well be somewhere else. There isn't any size or thermal
advantage to separating out the power supply, since the audio chassis would still be the
same size and heat dissipation.
Here is a thread that has some good PSU pictures. You can see the exact capacitors being used. I think these higher total capacitors than the PSU needs, but I don’t think it matters - Vishay 22000uf 35v. I also ask the same question about the CL60 but Digikey doesn’t have the part, had to order it from Mouser.
I just bought all the stuff myself but haven’t received it yet and went through all the questions you have and eventually figured it out after a month or so.
Here’s the post
diyAudio F5 Build Guide
Here’s the post
Snubbers are not required for the F5 so don't worry about that.
Suggest these three things for a successful build:
- Buy the F5 kit of parts from the DIYaudio store. You will have all of the correct parts that have proven to fit the board and play well together. It's cheap insurance.
- Follow the 6L6 build guide religiously. Again, a proven build process that others have followed with great success.
- Continue to ask questions in the F5 forum if unsure about any step.
Can anybody give me some advice on what jumper cable and wiring I should use throughout the amp? Getting a lot of conflicting information. @Silasmellor, so the purpose of the snubber is to clean up the power from the Transformer? are there any other parts that can be considered optional?
Also I'm confused as to whether I need 4 or 8 capacitors.
This guy uses 4 An illustrated guide to building an F5
This guy uses 8 diyAudio Power Supply Circuit Board v3 illustrated build guide
Is it because the second one is universal as opposed to just being enough for the F5?
Why not wire them in dual mono, isn't that preferable for the second one instead of connecting them?
I suggest you use the universal PS board:
Universal PSU – diyAudio Store
It has room for 8 caps (with diameter <=35mm) so anything over 15000uF each will
meet the original PS capacitance amount.
My last few PS were built using 8 x 22000uF caps.
Oh okay cool, so the Universal PSU board has space for 8 caps. Thats good. Thanks for all the help. The F5 kit and boards should be getting here soon so I'll solder that up and do some more research in the meantime. If I have more questions is this a good place to ask or should I start a new thread?
One more question-what type of jumpers should i use to connect the boards?
- First time F5 build
