First time F5 build
First time F5 build
Old 15th March 2019, 02:52 PM   #91
rayma is online now rayma  United States
Originally Posted by Trismos View Post
I may indeed! I will check it tomorrow. Getting to be a pain to pull that board in and out now. Thx for the hint.
You don't have to remove the board, the flat side of the LED is the cathode, which should go to ground.
Old 15th March 2019, 02:53 PM   #92
You don't have to remove the board. The flat side of the LED is the cathode,
Old 15th March 2019, 04:54 PM   #93
Trismos is offline Trismos  Canada
But I will have to pull it to remove / replace the LED. Which should be a fine pain in the butt.
Old 15th March 2019, 05:43 PM   #94
But first determine what the problem is.
See if LED is in the right polarity, and measure the resistor.
If the LED is reversed, there will be 25V across it,
since no current flows in the series resistor.
If your DVM has a diode test function, it can light up the LED,
if the positive meter lead is on the LED's anode.
Old 15th March 2019, 05:53 PM   #95
See? Besides just getting to put together a great amp, I get to learn things. Thanks so much for your help! Will test this out tonight.
Old 16th March 2019, 02:16 AM   #96
....If your DVM has a diode test function, it can light up the LED,
The LED was in backwards. Tough little sucker to get out of there as well. Ended up breaking it so I could work one lead out at a time.
So I see I've essentially stepped into jakesnake1's thread on his build. I will create my own now and post some pics. I have pretty much everything to finish as well as some questions of course. Thanks for your help here rayma.
First time F5 buildHide this!Advertise here!
SSE first time build! johnzm Tubelab 34 1st June 2017 10:56 AM
ok time to build another one ArcticBreaze Instruments and Amps 4 4th March 2014 03:51 AM
First Time Pre Amp Build nikolas812 Tubes / Valves 3 2nd April 2009 01:20 PM
K-12G First Time Build TubesRule6656 Tubes / Valves 7 29th April 2007 07:17 PM
Time to build the F3 auriontoledo Pass Labs 18 18th January 2006 02:39 PM
Copyright ©1999-2019 diyAudio
