LateSit
LateSit
Old 24th November 2018, 12:45 PM   #91
Soundhappy is offline Soundhappy  France
Soundhappy's Avatar
Power supply filter from original B1Triode schematic is efficient against the smps noise
B1 with Korg Triode
Don't expect very low distorion numbers, was generaly recommended for amp's with 20dB of gain and H3 dominant character.
Thanks again Pascal for Your passionate work sharing , descriptions,schematics, photos and video's.
Very well documented thread Have a nice day
class A amplifiers with full range speakers
sings like angels in heaven
Old 25th November 2018, 03:08 PM   #92
Pascal Nguyen is offline Pascal Nguyen  Australia
Thanks for your guidance, will keep it in mind.
Old 25th November 2018, 03:21 PM   #93
Default B1 with VFD - Critical Tuning
I imitate the B1&Korg circuit with minor modification to suit the 7 segments VFD.
“Imitation is a sincerest form of flattery”
Thank you Mr. Pass.
YouTube
File Type: png D016D4C9-398D-4445-8ACB-88C6491F7064.png (57.5 KB, 279 views)
Old 30th November 2018, 01:32 PM   #94
Originally Posted by Pascal Nguyen View Post
For a fine tuning without notch filter, one can use the Arta with an obsolete computer (don’t use your pc, sooner or later you will kill your soundcard).
Get to the minimum distortion, then back off to CW and CCW for your favourite H2 dosage, take notes of plate voltage (2 voltages, one for -H2 and one for +H2)
Inject some musics in and retune the bias to the plate voltage as noted, the nice sounding is the bias with Positive H2.
My project is nearly done, all four driver have been built and tested, the fifth VFD (sounds nice also) is waiting for some Russian Nixie tubes with very short filaments to replace the Samsung’s.
Cheers
File Type: jpg 0405D51C-6F36-4339-B08E-E26B5C80C03D.jpg (820.0 KB, 223 views)
Old 3rd December 2018, 01:06 PM   #95
Cheers
Set both VFDs for same gain, one is brighter than the other!!!
Without any input, very close to speakers, I can hear the resonance, like some one strikes a gong few minutes ago.
YouTube
Cheers
Old 4th December 2018, 12:37 PM   #96
Default The Sound of an One Aussie dollar Tube
My project is nearly done, all four drivers have been built and tested
Cheers
My 6J1 ŕ la B1 is sounding really nice:
YouTube
Grid bias and plate current are exactly same from the eBay 6J1 preamp kit.
Only a minor modification at the power supply section had been performed by removing all steering diodes for voltage multiplication.
There is an error from my last schematic diagram of the 6j1 driver.
A grid resistor R11 has been amended.
Cheers
File Type: png D3B71A52-A399-4F74-84D8-F72AC4507B8C.png (59.7 KB, 157 views)
Old 4th December 2018, 02:01 PM   #97
dady is offline dady  Europe
dady's Avatar
Send a message via MSN to dady LateSit
Hi, why the 33µF coupling cap? you can use one of fraction of this value without low pass effect 1µF is fine or 0.5µF. And this could be non polarized.
Also you can avoid the use of the first buffer. The amplification amount is <1, it has input high impedance, near the same of the valve.
Try to use a cascade buffer without cap between the stages.
Best Regards
Esteban Bikić
Old 5th December 2018, 11:58 AM   #98
Simply due to my availability of having many 33µF capacitors at the time of breadboarding.
Fc (33µF — 4.7kOhm) = 1 Hz
That value was noted and used in my drawing.
Having only low impedance sources (Android phone), I do need a buffer interface to avoid impedance mismatch.
Will do some more reading to build a direct coupling between stages without capacitor.
My appreciation for your comments
Kind regards
Old 7th December 2018, 01:40 AM   #99
Default With Love From Russia, Nuvistor 6S51N-V
From our forum, a mixed bag about 6S51N-V performances hit my search.
Stubbornly I placed an order of 20 nuvistors from Russia, to play with my LateSit.
Quite nice sounding
YouTube
A coupling capacitor C11 is missing from my last drawing, another one C12 is amended to cathode resistor for AC bypassing.
Please change C1 value to 0.01uF or omitting this cap, I need it for avoid RF breaking in due to a kW transmitter is in proximity.
Cheers
File Type: png 68E093AF-44BD-4163-9328-94A6E4151A57.png (60.2 KB, 77 views)
Old 7th December 2018, 01:52 AM   #100
Soundhappy's Avatar
Quite nice sounding
Excellent Nuvistor preamplifier thanks Pascal for video show.
Salutations
LateSitHide this!Advertise here!
