SissySIT
SissySIT
Old 22nd October 2018, 12:35 AM   #621
sontero is offline sontero  Italy
sontero's Avatar
I apologize to everyone who participates in this thread. Mine is perhaps a trivial request but so far I have not seen the problem of choosing power supply very developed. in short, what would be the simplest and most effective solution to feed sissysit? what scheme to adopt? It has aroused great interest in me to be able to use a capacitor multiplier which I believe is capable of considerable performance.
The Easy Peasy by Juma for ex. It would seem to me simple and of excellent performance but I did not understand if it could sustain a constant current of bias of 1.7 - 2A.
ZenMod what is your idea about it?
Old 22nd October 2018, 12:43 AM   #622
Ben Mah is offline Ben Mah  Canada
I will be building a First Watt type of CRC supply, dual mono with probably 18V 300VA transformer per channel.
Zen Mod loves dual mono.
Old 22nd October 2018, 01:02 AM   #623
sontero's Avatar
thank you for expressing your opinion .... and ... I also love the dual mono absolutely
Old 22nd October 2018, 01:23 AM   #624
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
SissySIT
dual 18Vac jobbie per channel, 250VA as minimum , two bridges , CRC ...... I'm using 33mF-0R1-33mF per rail
no multipliers , no regs
each Donut having own fuse and NTC on primary side , also each channel having NTC from main GND to chassis
so , just power cord and switch are shared between two PSUs
final result is , as always , something as 22V5dc per rail , no fuss/broom/noise/tizzzz/zing
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 22nd October 2018, 01:42 AM   #625
sontero's Avatar
Amen
you could not be clearer .... nothing I can add
I'm satisfied
Old 22nd October 2018, 02:43 AM   #626
Zen Mod's Avatar
SissySIT
Default Few more things aboout Donuts
if possible , static shield (so called screen or blind winding between primary and secondaries ) can't harm
also - strip shield (around Donut perimeter) is welcome , too
both are either normal or optional , at decent Donut Vendors
Old 22nd October 2018, 08:19 AM   #627
fabiodipietro27 is offline fabiodipietro27  Italy
A little question.... Would it be possible to use a 24V ac transformer to have about 32v DC? Should you vary the bias? Would it be too hot to dissipate? Could we have advantages or disadvantages? Thank you all. Fabio.
Old 22nd October 2018, 09:10 AM   #628
Zen Mod's Avatar
SissySIT
you can ......... but that's waaaaay too much for my liking .........
let's reserve that ( and higher than that ) for GodzillaSIT , with some other mosfet down
Old 22nd October 2018, 11:18 AM   #629
Thanks, Zen Mod, your replay is clear.... It was because I have two 24v 500w not used. Regards, Fabio.
Old 22nd October 2018, 12:10 PM   #630
Kris0603 is offline Kris0603  Sweden
I'm thinking of putting either a DC protect in or a couple of large elcaps back to back bypassed by a film cap in series with the speaker, and seeing if i can't squeeze out a few extra watts, but would need to make sure that if the 9240 goes that it doesn't take the optocoupler or the hall sensors or any of the other components out with it.
SissySITHide this!Advertise here!
