SissySIT
SissySIT
Old 16th September 2018, 02:31 PM   #261
pras1170 is offline pras1170  China
Default I need to prepare materials
Originally Posted by Zen Mod View Post
for THF51-S , body is drain ( no need for isolation for test , just keep heatsink electrically from other voltage potentials , other than + rail), fat protruding pin is source,while thin protruding pin is gate
again , any power N channel JFet , having ebough cojones , and having gate voltage in range of -1 to -3V6 is adequate for SissySIT circuit
if you sort your P channel mosfets , and use those with highish gate voltage (for -19 to -25V and Iq 1A8 to 2A) , in area of -4V5 , JFet can have even -4V gate voltage for intended conditions
have more questions , shoot
I need to prepare materials: ammeter, voltmeter, fan resistance, adjustable resistance, 9V battery, 24V power supply
I need to weld well to make a test machine, right?
I will try to prepare the materials and upload the pictures
Old 16th September 2018, 02:35 PM   #262
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
SissySIT
I am off the grid (absent from web entirely) from tomorrow morning to Friday
if you need help , somebody will chime in
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 16th September 2018, 02:42 PM   #263
good
Thank you for your
Old 17th September 2018, 07:13 PM   #264
Ben Mah is offline Ben Mah  Canada
Here is my test rig in action.
I used a wall wart power supply in place of the 9V battery. It actually outputted 12VDC even though it was rated at 9VDC. However, since the 10K pot limits the voltage to the THF-51S, the higher voltage was not a problem. I did not have a power supply of 19 to 25V so I borrowed the power supply from one of my projects. I temporarily disconnected the power supply and took the power off it. However, the supply voltage was much higher than 25VDC so I plugged the supply into a variac and reduced the input AC to the point that the supply outputted 24VDC.
For connections, I used clip leads for everything except for the resistor in the bias supply. I soldered that to the 10kohm pot. For the 1kohm resistor, I soldered two 600 ohm resistors in series to the pot. I figured 1.2kohm was close enough. One thing to keep in mind is that with the use of clip leads, care must be taken to not jar any connections loose while the test setup up is powered up. You do not want to lose the bias voltage while the main voltage is applied.
The THF-51S was attached to a heat-sink, with silicone heat-sink compound in between the sink and THF-51S. The aluminum heat sink that I used was 325mm x 120mm and weighed 1.3kg. After five minutes, the THF-51S was hot but I could still keep my finger on it. As Zen Mod stated, the THF-51S should be heat-sinked. A fan alone is probably not adequate cooling. With my heat-sink, it was big enough that I did not need a fan.
I tested the THF-51S at 24V and 1.8A. As can be seen in the photo, I used three meters. One inline for current and one each for Vgs and Vds.
Old 18th September 2018, 11:56 AM   #265
Kris0603 is offline Kris0603  Sweden
Has anyone considered trying to run two SissySIT channels off of a single transformer? With an autoformer we could parallel channels in-phase, but we'd have to use it as a traditional interstage transformer if we'd want to phase-split and feed two channels in opposite phase, or am i missing something?
Old 19th September 2018, 12:27 AM   #266
Default THF-51S tested
I received my THF-51Ss from watanabetomoaki last week. I purchased four and they arrived nine days after I purchased them so that was good.
They were grouped in twos with numbers handwritten on the bottom. One group had 2.5 written on both and the other group had 2.2 on one and 2.4 on the other.
I tested them at 24V and !.8A as shown in the post #264 above. The results were as follows:
2.2............-3.11V
2.4............-3.19V
2.5............-4.46V
2.5............-3.54V
Three of the THF-51Ss are quite usable for the SissySit, although the -3.54V is getting close to the limit. The -4.46V is much too high.
I don't know the meaning of the handwritten numbers on the bottom of the devices. I sent watanabetomoaki a message four days ago asking the question but I have not heard back from him yet.
Has anyone else tested their THF-51S from watanabetomoaki? Did yours have handwritten numbers on them, or do you know their significance?
Old 19th September 2018, 01:28 AM   #267
SPWONG is offline SPWONG  Hong Kong
I got 2 from watanabetomoaki, one marked 1.7 and the other marked 1.8 by him.
I tested them at 19V and 1.8A, both got -2.3V.
Old 19th September 2018, 02:32 AM   #268
Default S G D
Hello, I have made the experiment
However, it is troublesome for me to send the picture to you in BBS. I sent it to you by email, but the display was not successful. It may be that your email has the setting of not accepting the email from strangers
All the emails I sent to others were successful and sent to you were unsuccessful
Now, S G D, I want to make sure the position of the foot
Left foot 1. Grid
2. Source
Base plate 3. Drain.
Old 19th September 2018, 02:35 AM   #269
Left foot 1. Grid
2. Source
Which one can answer me, I think it is like this
Are you the same idea?
Old 19th September 2018, 02:36 AM   #270
Left foot 1. Grid
2. Source
3. Drain pole
SissySITHide this!Advertise here!
