SissySIT
SissySIT
Thread Tools
Old 20th September 2020, 06:46 PM   #1021
cal3713 is offline cal3713
Zen, another question as I try to force myself to understand the circuit.
For the voltage source that's added to the signal in the ltsplice diagram. Will just directly connecting to V+ & V- of an amp board work?
(And sorry if this got double posted. I swear I submitted it earlier, but couldn't find it in any of the threads I post in.)
Old 20th September 2020, 08:04 PM   #1022
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
SissySIT
V1 in lower pic in #1018 is AC signal source
preamp, CD, TV, phone, whatever
in mentioned amps , there is JFet buffer in place of V1
just general remark - xformers are AC realm beasts
toss enough DC on them, all you'll get is smoke
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 20th September 2020, 08:16 PM   #1023
Thanks for the continuing education.
I was confused by seeing both the voltage source and the "IN" connection. I just got a testing circuit worked out on the breadboard and was able to directly show myself the effects of disconnecting various coils on volume. Super useful for pounding it into the dumb head.
As always, thanks for your patience and help. Super simple once it comes together...
Old 29th September 2020, 03:07 PM   #1024
G600 is offline G600  France
SissySIT
Some news on the SissySIT front.
It's finally outputting some fine music.
Adjusted a while ago, but waited for some iron to finish my preamp.
I must receive the finished front panel from Schaeffer in a few days.
Two blue LEDs to be installed, and bingo.
Thank you, ZM!
Old 29th September 2020, 05:54 PM   #1025
Zen Mod's Avatar
SissySIT
if you're happy, I'm happy
Old 8th October 2020, 08:02 AM   #1026
pras1170 is offline pras1170  China
I resumed work today, and continue to sell 2SK182ES 2SK180 2SK1058 2SJ162 2SK1530 2SJ201 LM350K MJ21194G MJ21193G MJ21195 MJ21196 MJ15025 MJ15024 MJ15015 MJ15016 THF-51N THF-51 If you need a transistor, integrated chip, you can contact and send @qq.com directly: 378632242@qq.com
Triode integrated circuit chip DIY power amplifier transistor MJ21193 MJ21194 LM350K LM150K LM3886TF THF-51S 2SK182ES ..... Sony Sanyo MOT ON NSC ST TOSHIBA HIT
Old 27th October 2020, 10:40 AM   #1027
mbrennwa is offline mbrennwa  Switzerland
mbrennwa's Avatar
SissySIT
As always, I am late to the party, and I apologize for not reading every single post of this thread -- it is simply too long.
I have been staring at the SissySIT schematic for a few days now. I don't get it.
The gate of the IRFP9240 at the bottom is driven by the input stage. The gate of the SIT on top is driven by the optocoupler. This looks like the IRFP is the active gain device, and the SIT is part of the current source, that follows the gain device. Shouldn't it be the other way round (SIT = gain device, IRFP = current source / follower)!? What am I missing?
Is there an overview / walk-through of the circuit somewhere? A link to this might be useful.
Old 27th October 2020, 12:43 PM   #1028
Zen Mod's Avatar
SissySIT
optocoupler's bjt with cap in parallel is firm stick between two gates
signal from xformer is pushing and pulling one end of that stick
other end of stick, naturally, follows
plenty of talk and mumble in link posted in post #1 of this very thread : Most Greedy Boy, of them all... or (there is no) DEFiSIT of Papa's Koans - Page 62 - diyAudio
Old 27th October 2020, 01:39 PM   #1029
mbrennwa's Avatar
SissySIT
Hmmm, I screened through that thread, but couldn't find the explanation. I can see how the opto acts as a stick between the gates. If the current through the outputs tries to wander off, the Hall chips will tell the opto to fix the length of the stick in order to keep the current fixed. But if the stick is a proper stick, and the two ends of that sick follow each other, then I'd think that both the SIT and the IRFP are driven by the input stage in the same way. I would have thought the SIT should be the gain device that is driven by the input, and the IRFP should be the current source that follows the SIT. Do you see where my brain goes wrong? I don't.
Old 27th October 2020, 03:41 PM   #1030
Zen Mod's Avatar
SissySIT
think M2, OS is simple mosfet PP source follower, biased with great sense of humor
now, just replace upper mosfet with SIT, move current senses to rails, so you can remove source resistors
simple as that ....... same stick used in M2 and in SissySIT
SissySITHide this!Advertise here!
Thread Tools
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
