Babelfish M25, AKA M2 on steroids, AKA M2-XA25 bstrd AKA M2 gone Berserk
Old 15th December 2018, 01:57 AM   #141
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
even if you're going "just" to sleep better , go for it
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 20th January 2019, 06:49 PM   #142
Russellc is online now Russellc  United States
Just wondering....Am I only one building this version? Finishing other projects first but I see many going for SissySit version, not much activity with M25.
I have every intention to build both, but given MOST, (not all) my speakers are fairly easy to drive, I am thinking about starting with Sissy sit version as first build. (As in before M25, way to late for "first" build)
Any other M25 builders out there?
Russellc
Pass B-1 preamp, Pass BA3 preamp, Pass F-5 Amp, Pass F-6 Amp, Pass BA-3 Amp, Pass M-2 amp, Pass Aleph J amp, Pass Pearl 2 Phono pre Tekton Enzo, Altec A7, Econowave JBL 2235H & B&C CD
Old 20th January 2019, 07:55 PM   #143
Zen Mod's Avatar
several B. M25 kits sent , but will they end as SissySIT ....... I can't tell ...... I mean - guess
I know that soon I'll have both fully made , as proper and complete amps , of my own!
contrary to earlier ones ....... I never finished my own specimens of Babelfish J , nor Babelfish J2
Old 20th January 2019, 09:21 PM   #144
cjfrbw is offline cjfrbw  United States
I have been listening to commercial First Watt M2. Because it has been such a shape shifter for me, I have been playing around with the strictly subjective aspects. At times, it is brilliant in wholistic, organic way but needs to be left on for a while to get this for some reason.
Anyway, with ribbon speakers, M2 works well down to 2.5R. However, it sounds better with 4R ribbon, but really locks in in sound quality at 8-10R using an impedance matching transformer. So at least with my speakers, it just sounds most optimal at the 8 and above impedance level, though it is quite good also at the lower impedances.
Want M2 to sound 'spooky' like VFET, with that special luminescence and gilded emergence from space, while still having the PRAT organic thing of M2? Use a directly heated triode driver/preamp.
I don't know why this would be, but it is special sounding. VFET doesn't need this and can sound 'spooky' on it's own or with a transistor preamp.
Maybe adding the second order harmonics from the tube to the more dynamic sounding, driving third order harmonic from the MOSFETs in M2 does something, but this, or course, is daft speculation with no objective foundation. The particular DHT tube is a tube rectified 26 tube. I would imagine many DHT tube drivers might give a similar result.
This is why I want to attempt my first DIY with the Korg B1 project (aside from it looking like an entry level project even I can tackle). I am curious how the Korg NUTUBE driver will effect the M2 sound compared to my VFET amps/or directly heated triode drivers with M2.
Old 20th January 2019, 11:05 PM   #145
dBel84 is offline dBel84  United States
My original intent had been to build the M25 as the Tokin SITs seemed few and far between, but then PRAS appeared and it seemed a no brainer to be able to reproduce something close to the reported magic of the FW SIT3..dB
Old 23rd January 2019, 04:39 AM   #146
Just ordered my Sits from Pras...
Russellc
Old 23rd January 2019, 05:03 AM   #147
oops - wrong thread ..dB
Old 23rd January 2019, 07:57 AM   #148
Zen Mod's Avatar
all ZM's threads are right ones ...... Off Topic simply impossible
Old 23rd January 2019, 02:56 PM   #149
Juntuin is offline Juntuin  Finland
Russellc
I'm going also for M25 as soon as I get kit from ZM. I have built M2x so wanna try CineMag this time.
Old 23rd January 2019, 03:51 PM   #150
kbergsson is offline kbergsson  Iceland
kbergsson's Avatar
I have M2 as well and am going for the S.SIT but with CineMags like you. Currently waiting for CineMag to produce a batch of the high nickel versions.
Babelfish M25, AKA M2 on steroids, AKA M2-XA25 bstrd AKA M2 gone BerserkHide this!Advertise here!
Pass XA25? WalterW Pass Labs 624 17th February 2019 06:12 PM
XA25 vs F7 jelt2359 Pass Labs 30 28th January 2019 09:07 PM
Pass Labs XA25 convert 120Vac to 240Vac input masterbearbear Pass Labs 8 9th July 2018 03:53 PM
Pass Labs XA25 review 2 picoDumbs Pass Labs 57 8th March 2018 02:52 AM
The BSTRD - Class A Tube Pre and PSU with Eagle Project Files skrodahl Tubes / Valves 6 25th December 2016 05:50 PM
Copyright ©1999-2019 diyAudio
