LX-mini Crossover Article
Thread Tools
Old 16th June 2021, 03:20 PM   #871
bullitt5094 is offline bullitt5094  United States
DIY Rookie
bullitt5094's Avatar
Are there additional details on the Fast 8 SLOB build somewhere? I actually have a pair of Fast 8s collecting dust. Maybe this would be a good build to utilize them. One reason they are collecting dust is I've never been impressed with their high end. If this is an OB project that includes a tweeter to help the highs, I'd be very interested. The 8 sounds great except for upper highs. And no... it isn't my hearing. My wife with bat ears commented on that the moment she first sat in front of them and my daughter (who inherited her ears from mom) had exactly the same reaction.
Bob
The Perfect Audio Component is Exotic, Incredibly Expensive, Horribly Inefficient, Unavailable and Toxic (Nelson Pass)
Old 16th June 2021, 05:15 PM   #872
DIY Rookie
LX-Mini + 6-24 ACN. Working extremely well for me!
Bob
Old 16th June 2021, 07:26 PM   #873
peppennino is offline peppennino  Italy
Galactic Hitchhiker
peppennino's Avatar
Originally Posted by wg45 View Post
Here's the info on my ACN/LX Mini set up for Papa's SLOB.
Is baffle step -2dB?
Lifetime Greenhorn | SL1210MK2 + DL103 | 834p TRLH + α2δ PSU1 | UBP-X800 + Linear PSU | Rasp 3B+ | JEL TDA1541/6CG7 | B1R2 | Aleph JZen (WIP) | Π 4 | DIY Rack | PASSdiy TV
Old 16th June 2021, 07:34 PM   #874
wg45 is online now wg45  United States
Try this thread-
Papa's slot loaded open baffle version#2
Attached is a rough build plan for the frame.
No reason why you could not add a tweeter. You could connect the tweeter to the FR with a capacitor.
That's the best part about the SLOB. It's a template for customization.
Old 16th June 2021, 07:49 PM   #875
DIY Rookie
Thanks! From there I found this https://www.firstwatt.com/pdf/art_slob.pdf And this Papa’s slot loaded open baffle version #2
Bob
Old 16th June 2021, 08:01 PM   #876
Yes, Papa's paper covers the much larger SLOB with 6 woofer drivers and lots of information on FR drivers. It's very informational, although some of the FR drivers tested are not available currently.
I built his smaller version, which is more of a "normal" sized speaker. I don't believe it is covered in his paper.
Old 29th September 2021, 04:29 PM   #877
Galactic Hitchhiker
peppennino's Avatar
Originally Posted by peppennino View Post
Hi all, I have a ACN basic kit (board + fets): could you help me to adjust the values for a pair of Papa's SLOB?
Finally it's coming... It's a long way to the top, if you wanna DIY
Old 13th October 2021, 11:22 PM   #878
Manolo47 is offline Manolo47  Puerto Rico
Default Bypassing low pass filter section
If I would like only use the bass hp filter and eq. section, bypassing the second half of the circuit -low pass filter- , from where would I connect the output in the xover? Thanks!
Old 13th October 2021, 11:43 PM   #879
avdesignguru is offline avdesignguru  United States
avdesignguru's Avatar
See attached.
Builds: Papa's B1, B1-Korg, F6, LxMini ACN, F7; Wayne Colburn's Whammy, Pearl II, BA2018; Mark Johnson's T2, M2x, Noir; Mike R's MoFo; Pete Millett's NuTube Buffer, NuHybrid, NuClassD; John Broskie's Aikido LV, A5 Attenuator; Jim Hagerman's Bugle2
Old 14th October 2021, 03:02 PM   #880
Thanks!
  Reply to this post
LX-mini Crossover ArticleHide this!Advertise here!
Thread Tools
Lx-mini Analog Crossover Nelson Pass Analog Line Level 27 10th April 2021 03:15 PM
Analog Crossover for LX-mini Nelson Pass Multi-Way 1 7th July 2018 09:51 PM
AES article on the ultimate active crossover hahfran Analog Line Level 3 17th May 2016 04:39 PM
Mac Mini dual DAC crossover OzMikeH Digital Line Level 2 12th January 2009 10:11 PM
Mini Crescendo article carlhemm Solid State 6 4th December 2006 04:37 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
